| Chip Amps Amplifiers based on integrated circuits |
#21 |
The new boards look great. Are you planning to sell them in the future?
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#22 | |
diyAudio Moderator Emeritus
My plan was to build one and test it, and have a few friends build and test a few also. I don't foresee any issues with the boards, I just like to be thorough. If anyone wants a set to try out, drop me an e-mail. I have a busy weekend, autocrossing with the wife, but will try to start a build next week. I located a heatsink in my basement today to use. -- Brian |
#23 |
Audio Engineer
Hi Brian,
You have used split bridges for the power supply for the two different rails and then shared the current paths back to the trasformer buy usign one big plane between the capacitors. Since you have split the rectification with two bridges, the rectifier currents will flow in a loop through the capacitor C10 and 12 for the +ve rail and C9 and C11 for the -ve rail. This means that to get the minimum rectifier noise on your star point you want to split the return paths for these two rectifiers and join them back at the connection between the two rectifiers. Then a third path should join at the rectifiers to feed the rest of the amplifer star. This way none of the rectifier currents flow in copper shared with the star point, this should reduce the ripple on the ground slightly. Since you have already had the boards made you could try this out by cutting two slots into the ground plan to isolate a path up to the "star point" OG gnd. This is only a minor point as you already have a good design but since you are cleary wanting to get the best out of it it may give you a slight improvement. Regards, Andrew |
#24 |
Question: why not square pads for polarized components?
#25 |
It looks good but whats up with the loopy traces. Wheres the nice 45* angles....
#26 |
I might be interested in getting a few of those LM4780 boards for myself, but I'd be using an external PS. Would it be advantageous to use some filtering caps on the amp board too?
EDIT: I see that the board can be snapped off for just the amp. The ground trace looks mighty thin on the top, though, between C1-C6 and CHG, OG1, OG2.
#27 | |
The boards are not made to snap apart. I put a line there for a reference, should anyone decide that they would like to cut them apart. I also added the 3 pads for wiring to an external power supply. |
#28 |
If I wanted to parallel the 2 channels of one board and then use two boards like this in a bridged configuration, I should't have any problems, should I ?
#29 |
It's better with regard to PSU and decoupling to bridge the pair of amps inside the single chip and parallel the two dual chips.
It reduces the current in each supply rail and removes much of the rail shut off that cannot be avoided with a ClassAB output stage. The rail currents approach the rail current modulation of a push pull ClassA output stage. |
#30 |
I like the concept! especially in stereo configuration this makes a great compact powerful package.
| Crossover Layout Comments | luvdunhill | Multi-Way | 13 | 4th February 2009 02:50 PM |
| Need comments on this P3A PCB layout | goering | Solid State | 7 | 27th August 2004 06:04 AM |
| My new Aleph layout. Comments? | louischia | Pass Labs | 12 | 18th May 2003 08:02 PM |
