Yey - LM3886 works like a charm Yey - LM3886 works like a charm - diyAudio
Old 16th January 2009, 03:42 PM   #1
Atilla is offline Atilla  Norway
Default Yey - LM3886 works like a charm
I've been reading about chipamps for quite some time now, making sure I'll have everything set up nice and sound when I start working on my own. I've had the parts in my desk for quite some time now, but today I finally got the soldering gun and got to work to finish them up.
I've a kit from chipamp.com, with a few tricks here and there to make it perfect.
So, the setup is:
2x120VA torroidal transformers with 2x24V secondaries. Those are wired trough 2A slow-blow fuses on the primary side (1 on each rail). This is plugged into 2 rectifier+smoothing boards from chipamp.com, with 3300pf WIMA caps paralleled across each AC input to lower the ringing frequency (optimum snubbing to be determined later, maybe - we'll see). I get perfect +/-34.7V on each rail. I connected and measured and nothing blew up! Awesome.
Those go through 3.15A fast-blow fuses (on each power rail) and plug into the two boards from chipamp, set up with the feedback cap on. I measured the DC offset with no source, no load and it was 5mV. So far so good, so I plugged in a 10ohm 15W resistor and measured the offset without and with source signal. Same story - awesome. So, confident, I plugged in my 8ohm, low-power test speaker and let it dance. 5mV offset on both channels, sound without any audible artifacts, everything just great!
I mean - of course, with a small fullrange speaker, without enclosure you cant hear much, but it did dance pretty well. I've high hopes for the sound of this thing.
Next is to set up a mains filter, with two thermistors for power-on surges as well. Which reminds me - should I substitute the mains fuses with 2A fast-blow, if I do that? Sounds safer to me.
After that, if everything is allright, it's enclosure and heatsinking time, while in the meantime I get hold of 2 speaker protection circuits, just in case.
I was so happy, I wanted to post right away, so no pics yet. Not like you guys don't know how those things look anyway.
I just wanted to say - thanks, for answering my noobish questions and for all the info that has been shared here. I rememberd quite a lot about simple electronics and learned quite a bit more. Cheers !
Old 16th January 2009, 04:00 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Congratulations!
Keep slow-blow fuses on the primary side of the traffo.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 16th January 2009, 05:21 PM   #3
Beftus is offline Beftus  Netherlands
Beftus's Avatar
Well done! Post some pics for us to drool over will you?
I just finished my dual monoblocks last weekend, my pics are in the Photo Gallery thread. I'm still amazed at how good they sound.
Old 29th January 2009, 08:23 PM   #4
So - after a little more hardware was salvaged or purchased, I did more tests and here goes:
Custom-made mains filtering. It will get neater, I promise. Or I'll scrap it, alternativelly:
Chips in testing, mounted on the heatsinks of the case I got. Wires everywhere, I'm going crazy:
Heatsinks. I've my doubts about 'em. I hope they perform, cause I love the case
3" cheapo 8ohm test speaker. If that guy is the judge - the amp kicks serious bottoms:
Those guys mean more business. They're also apparently 4ohm, cause the right channel got a lot warmer than the left while testing:
It's ON, baby:
Old 30th January 2009, 07:17 AM   #5
pacificblue is offline pacificblue  Germany
The heatsink could be okay for 8 Ohm loads, if you have one per IC. I wouldn't be so sure about 4 Ohm loads, especially since your supply voltage is quite high and you are using the isolated package. Consider adding a fan.
You should absolutely add thermal grease, otherwise the heatsinks won't help at all.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 30th January 2009, 07:31 AM   #6
Mm, yes - one heatsink per chip. It could hold. It worked even without thermal grease - this was just a temporary setup for testing. I've got a whole lot of thermal paste, I won't forget!
I didn't plan on making it run 4ohm loads to begin with, that's why I got the higher voltage trafo. If it ever has to do that, we'll have to use it at very low volume.
Fans are indeed an option, but only if things go really bad. I don't like noise.
Old 30th January 2009, 07:42 AM   #7
ace7one is offline ace7one  Norway
I think it all will work just fine, I've used two of those IC on much smaller heat sink than yours, and it worked -> still works just fine. It never becomes too hot so you can't touch it.
Remember that when it feels too hot it is only a little over 40 Celsius and for Si that is not too much.
TDA
Old 30th January 2009, 07:45 AM   #8
The sinks are also external - they're the sides of my casing. They're 280mm long and about 50mm high. they should be able to get the heat out, even if they're not perfect.
Old 30th January 2009, 02:21 PM   #9
Remember also that there will be ~55 W to dissipate with those rails and 4 Ohm speakers. The LM3886TF has a thermal resistance of 2 K/W, hence will be 110 K hotter than the heatsink.
With 8 Ohm speakers all will be well.
Old 30th January 2009, 02:24 PM   #10
I should put a sticker on them - No 4ohm impedances, please.
A minute or two of testing won't cook them though.
Yey - LM3886 works like a charmHide this!Advertise here!
How this 317 PS works? pftrvlr Power Supplies 2 28th April 2008 12:21 AM
CCS, how it actually works? timf Tubes / Valves 17 23rd January 2006 12:20 AM
My LM3886 GainClone almost works! Big Pete Chip Amps 3 9th August 2005 07:11 PM
My first GC(lm3886) +fire works+ please help rs1026 Chip Amps 5 6th November 2004 04:49 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
Copyright ©1999-2017 diyAudio
