Yey - LM3886 works like a charm
Old 30th January 2009, 05:46 PM   #11
pacificblue is offline pacificblue  Germany
Originally posted by Atilla
A minute or two of testing won't cook them though.
..as long as you don't crank it up too much. Those ICs come with a good protection system built-in. And that is the point. When the protection system switches the amplifier off too often, it becomes a nuisance.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 11th March 2013, 09:41 AM   #12
tonitonitoni is offline tonitonitoni  Croatia
Originally Posted by pacificblue View Post
Remember also that there will be ~55 W to dissipate with those rails and 4 Ohm speakers. The LM3886TF has a thermal resistance of 2 K/W, hence will be 110 K hotter than the heatsink.
With 8 Ohm speakers all will be well.
been using mono lm3886tf on very small heatsink and 4 ohm speaker on 38.5v rails ,i think 200va toroid maybe more,, spike is heard after few minutes on max volume but not gonna burn lm no matter how hard i try to burn it..i think
voltage drop kills it when people take 120va trafo on ab class amp almost 70 watts rms
sry on bad langugage
edit:and sorry i didnt saw 2009 year
Old 14th March 2013, 04:44 PM   #13
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
I've got parts for a lm3886 gainclone too. I was thinking of mounting the lm3886 directly to the bottom of a rather large case. How hot do these things get?
Old 15th March 2013, 07:41 AM   #14
gmphadte is offline gmphadte  India
It will work ok on the case, but see that you mount these not too close, so that the case is shared individually by each IC. The ICs should be isolated from the case metal if you have the non-isolated version.
Moreover if things start getting too hot, the SPIKE protection in the chip will kick in, which you will hear as distortion.
Gajanan Phadte
Old 15th March 2013, 02:23 PM   #15
Thanks. I'll isolate each chip from the case. I might even use a piece of copper between the case and chips.
Yey - LM3886 works like a charmHide this!Advertise here!
How this 317 PS works? pftrvlr Power Supplies 2 28th April 2008 01:21 AM
CCS, how it actually works? timf Tubes / Valves 17 23rd January 2006 01:20 AM
My LM3886 GainClone almost works! Big Pete Chip Amps 3 9th August 2005 08:11 PM
My first GC(lm3886) +fire works+ please help rs1026 Chip Amps 5 6th November 2004 05:49 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 11:24 AM
Copyright ©1999-2017 diyAudio
