| Chip Amps Amplifiers based on integrated circuits |
1st post and finally took the plunge. Was hoping some of the more experienced builders could offer some advice on where I should assemble the internals to my GC. Mostly the amp Brds and the power supplys. I have looked thru the gallery and got the basics. The enclosure is from an old series 1 TIVO unit that I gutted.
I have a Dual Mono Block setup from BrianGT. Two 250v xformers 2x25v which will be powering a pair of Klipsch Ref IV RF62's. Thanks to BrianGT and this great DIY forum. -BB |
#2 |
ok trying to attach photo......
#3 |
once again
#4 |
Hey that is pretty good.
I cannot tell where your input/output connectors are going? On the top? (I will assume). I would swap locations of chip boards and the PS Capacitor boards. Your output is on the back/top right? So put the PS Cap boards on the front and the chip boards on the back. This will keep the AC away from your amplifier boards. Are you going to use the fan?
My DIY audio projects- PartTimeProjects.com. |
#5 |
Yes that's a excellant idea thx. Not sure if I will use the fan. Is there 12v I can tap off of without interfearing with the circuit?
New pic with input/output labeled. I want to cut out the back under the input/outputs for the heatsink for the amp Brds. Thx... -BB |
#6 |
Seems like a waste not to use the fan since its already there. You could use an LM317 12 volt regulator (use heatsink on it!) to get 12 volts from your + supply. Or smaller voltage to make the fan quieter. Or make an adjustable voltage circuit as shown on the data sheet.
Or you could make a temp sensing circuit using a bistable switch (Mouser part 802-STC-120, here). Put the switch on the heat sink and use it to automatically flip on the 12V power when the heat sink gets too hot (it closes) and flip it off when the sink cools off (it opens).
#7 |
Awesome idea. Thanks for the link and especially your time. I checked out your website. Nice stuff!
It's funny because I have done some of the same mods you have including the corner base traps (using 3 24" insulation rolls stacked) and the same acoustic treatments for my walls in the theater. I think the fan is a must since I"ll have around 34v for rail voltage so the chips may get a little toasty. -BB |
#8 |
Yeah, I got a room with a bunch of dorky stuff all over it. It used to be ultra high end audio - Wilson Watt/Puppy, Goldmund Mimesis, Wadia, Cary, sonic frontiers, Balanced Audio Technology, and now its mostly all DIY. A lot more fun to listen to your own stuff.
If you use an LM317 to drop the voltage be advised that going from 36-12V will cause it to get quite hot (its limit is a 40 volt drop so you should be fine), make sure to put a good size heat sink on the regulator. Those little bast**rds get hot!
#9 |
Will do thanks. Your so right about listening to your own stuff especially knowing you didn't spend a fortune and you have great sound!
I have another question if you don't mind. I have Avel Y23 xformers and the schematic on the side of it is not making much sense. Should probably call it a night. Here is the data sheet scroll all the way to the bottom. http://www.partsexpress.com/pdf/avelspecs.pdf I'm hooking it up 115v. If i'm reading it correctly I should tie Blue and Violet together (neutral) and Brown and grey together (Hot) right? I'll need to tie the second xformer to these same connections so it's fed the same I think. Input: for 110 volt Blue and Violet neutral Brown and Gray line Output: Red AC to rectifier Orange AC to rectifier Yellow and Black to ground or Output Black AC to rectifier Yellow AC to rectifier Red and Orange to ground Thanks... BB |
#10 |
Hey man, you saw the web site! Look at the Picture and Picture.
blue and viloet get tied together to AC in brown and gray get tied together to AC in It is AC so does not matter which is line and which is neutral. Red and orange get tied together to ground Black goes to the rectifier Yellow goes to the rectifier Good thing I used an Avel too. primaries get tied together on the AC input side, same coloring and connections.
| Really not satisfied with layout need advice | Yoshy | Chip Amps | 6 | 12th June 2009 05:57 PM |
| Some help/advice with a guitar amp layout. | bonescan | Tubes / Valves | 5 | 20th May 2009 12:27 PM |
| Layout and wiring advice | Nohabla | Chip Amps | 4 | 28th January 2009 01:46 PM |
| SMPS PCB Layout Advice | microsim444 | Power Supplies | 2 | 22nd January 2009 08:27 AM |
| Advice about PCB layout | Yoshy | Parts | 0 | 8th January 2009 02:05 AM |
| Page generated in 0.11845 seconds (81.91% PHP - 18.09% MySQL) with 11 queries |
