Old 20th January 2009, 11:18 AM   #21
col is offline col  Australia
col's Avatar
one of these with a 600VA trafo might do you:
http://connexelectronic.com/product_...147bnpktbev7l7
use their power supply too.
Iv'e just built one of these, it sounds great.
there is some more info in these forums just search TA3020
col.
http://www.minirig.org.au
Old 20th January 2009, 12:33 PM   #22
fredos is offline fredos  Canada
Call me, 514-835-3846, I speak french too. I will show you room and give you some advise and direction to make your 500W amp...But just be prepared to put what you need and dont cut corner. I hate people that do thing cheapest as possible. And I will not sell you anything, but give you direction where to find right parts. My biggest amp was a 10 KW RMS into 4 ohms...
Fredos
Old 20th January 2009, 12:33 PM   #23
homemodder's Avatar
Yep I would say SBS is a little overdoing it on marketing terms, what :bs: He says its the best rated sound in clubs and by audiophiles, clearly he doesnt even know what audiophile means, I bet those arent lm3886 chipamps anyway.
I see one very good suggestion here though, its by CJ900RR, now a amp around this with high power is very good, I tried one, comes much closer to a audiophile amp and abuse is no problem, design the output stage well. There are another 2 chips in the same range which could be better as they have higher output to drive a outputstage, all depends on the outputstage design. Also take a look at fotios amp in solidstate threads, thats most probably better souding than most pro gear, and built like a tank for this type of application.
Old 20th January 2009, 08:49 PM   #24
Default Re: Power Amp for clubs.
Originally posted by infectdrhythms
The idea is to first create a 500W stereo power amp so I can plug in to the DJ booth at the club.
Thanks!
Who needs 500W Stereo in a DJ booth Better you think about some sealing instead of a huge diy power amp ... If you need so much power only for monitoring, something else is wrong. Just my two cents.
regards
the truth is somewere
Old 20th January 2009, 09:39 PM   #25
Not really...sometime we provide up to 13 000watts for DJ monitoring in big rave party! The minimal we provide for DJ monitoring is a pair of JBL Eon (crap by the way!), so that's 800watts and they blow horn lot of time! DJ are deaf..
Hifi clubs in Sydney stoolpigeon Clubs & Events 0 8th May 2009 11:20 AM
Audio Societies or DIY Audio Clubs vdi_nenna Everything Else 0 10th March 2008 06:59 PM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
Blues clubs in New Orleans? Restaurants? harvardian Music 2 13th January 2003 04:38 PM
Page generated in 0.09401 seconds (71.71% PHP - 28.29% MySQL) with 10 queries
