Old 14th January 2009, 12:24 AM   #1
Default Help identyfing capacitors on lm3886 briangt
Hi
I am in the process of building a lm3886 using pcbs from BrianGT.
I have managed to find out all the parts except the square blu capacitors (C3,C4,Cz on Amp Board and C1 to 4 on power supply board)
Pictured on this link.
Could sombody please give me the type and physical dimensions of the capacitors and direct link would also be great.
Sincereley Julius
Old 14th January 2009, 10:41 AM   #2
Beftus is offline Beftus  Netherlands
Beftus's Avatar
I bought Vishay-Roederstein MKP1837 caps for these thinking they would fit. They don't, they are larger than the blue caps Brian supplies. You will not be able mount them all on the same side of the PCB. See picture.
Old 14th January 2009, 01:53 PM   #3
Try a BC Components 2222 416 41004. It's 5mm, should be small enough. He lists it's a BC cap on the parts list, so that's likely the one.
Old 14th January 2009, 02:35 PM   #4
ClaveFremen's Avatar
Evox-Rifa PHE 426 (RS 414-7614) would fit everywhere but not in C3, C4 if C1 and C2 are larger than 10mm (amp board).
In my chipamp.com gainclone I've left off C3, C4 (in both amp and PSU boards) because this way sound is smoother.
You can read more about it in my post about PS decoupling caps in Gainclone.
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 14th January 2009, 11:21 PM   #5
Redshift187, thanks for the help.
ClaveFremen, interesting thread.
Ordered one with 7X11X6 mm and 5 mm spacing hopefully it will fit,
or else Beftus suggestion about mounting the capacitors souns nice, thanks
Thanks again for all help
Old 15th January 2009, 06:32 PM   #6
Beftus's Avatar
You're welcome Mr. Julius!
Good choice of chip amp BTW. I have just finished my dual monoblock setup. I'm very pleased with the results. I'm sure you'll be too.
Old 15th January 2009, 07:45 PM   #7
Good luck and enoy!
Dario
BrianGT 680W LM3886 Amp krips Chip Amps 33 10th May 2009 10:02 PM
Problems with Chipamp (LM3886) BrianGT Puffin Chip Amps 44 17th October 2008 11:47 AM
LM3886 BrianGT amp complete, slight hum wigginjs Chip Amps 34 5th March 2008 10:55 AM
Building an LM3886 BrianGT Kit -- Questions wes-ninja250 Chip Amps 10 29th September 2005 12:35 PM
BrianGT's LM3886 Kit scott_jcp Chip Amps 11 4th March 2005 07:07 PM
Page generated in 0.34222 seconds (23.93% PHP - 76.07% MySQL) with 10 queries
