Old 13th January 2009, 12:23 AM   #11
huy5005 is offline huy5005  Canada
Try with 20hz tone, measure the supply rail voltage if you have voltage fluctuation, then your need larger cap or larger power supply or regulated power supply which provides enough current for the amp.
Old 13th January 2009, 04:06 AM   #12
raypalmer's Avatar
Has anyone found any significant improvement jumping from the 1500 Panny FC caps to a higher value panny fc? 3300 etc....
Wherever you go there you are.
Old 13th January 2009, 06:37 AM   #13
Reality first!
ClaveFremen's Avatar
Interesting!
Nice Idea the 20Hz Tone but 10000uf +100uf isn't enough? (see photos from first post)
Next test session I would give it a try!
Aren't you referring to values of Peter Daniel's kits'reservoir/smoothing caps?
Mine is from BrianGT so reservoir/smoothing caps are 10000uF!
Or you refer to 100uF PS decoupling caps?
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition GB Second Run
Old 14th January 2009, 11:29 PM   #14
Reality first!
Originally posted by mikesnowdon
I think I will build a diy amp from scratch soon and Im quite keen on the chipamp.com kits. How does yours compare to other amps you have tried?
Originally posted by ClaveFremen
Answering you question:
well, it maybe sounds a little better than my modded marantz receiver (in this moment it is still the pre) but I have to swap back speakers to the Marantz to say for sure!
Well, yesterday I branched again my Marantz receiver to the front speakers...
The difference is HUGE: the Marantz is bit more polite with highs (a bit of harshness less) but soundstage is a lot smaller, particularly in depth, basses are less controlled, channel separation is in another league (thanks dual-mono!!) and there is quite less dynamic.
Conclusions:
- My Gainclone is a big improvement over the power amp section of my Marantz receiver.
- Small values bypass of good electrolythics isn't always the best thing after sliced bread...in this case they're a detriment of sound quality.
Dario
Old 15th January 2009, 04:07 PM   #15
mikesnowdon's Avatar
Hi Dario.
Were the different caps you tried all the same value's?
www.drugfreeworld.org
Old 15th January 2009, 04:37 PM   #16
Reality first!
Hi Dario.
Yes.
100uF 50V for the Elcos and 0,1uf for film bypasses.
I've ordered some Wimas MKP2 0,1uF from Germany. I think they will arrive at the end of next week.
I want to try some different bypass caps... MMKs and Epcos were not good there.
If someone had good results with others 0,5mm led spacing bypass caps not too costly I would try them.
Dario
Old 16th January 2009, 09:13 PM   #17
Do you have voltage fluctuation at the supply rail?
For the cap, i tried with so many different caps. The larger cap will make the beauty of mid and high disappear. In fact, Panasonic FC 1500 cap is a good choice when you have a large transformer (larger cap doesn't help the bass though for my case). I think the bass issue is the problem of amp and speaker matching. if you want, you can try Carolsm snubbed power supply which i found that it is excellent with small transformer and picky speakers. Don't forget to check Peter's threads 'cause he has done so many experiments perhaps,, drop him a line
Old 16th January 2009, 10:26 PM   #18
Reality first!
I've measured voltage fluctuations with a 20Hz sine tone and voltage varies from 33.16 and 33.19 Volts on V+, hence with 0.03 Volts variations (V- the same).
To me it seems OK, isn't it?
Your Gainclone is a kit from Peter Daniels or similar?
I asked you because mine is from BrianGT and includes Snubberized CarlosFM PS, Zobel Network, 10000uF smothing caps and 100uF Decoupling caps on chip rails.
Dario
Old 16th January 2009, 10:50 PM   #19
That's very good. My kit is from Daniel.
With the 50% volume of sine 20hz from my sound card, my voltage drop down 1.50 volts V+ to gnd.
Old 16th January 2009, 11:28 PM   #20
Reality first!
Seems to me that we're talkink about different things
I've played the 20Hz tone and measured how V+ to gnd varies reproducing the tone.
With no music or tones V+ to gnd measures (V+ to gnd) 34.99 Volts, so it's a voltage drop of 1.80 Volts
I suspect you were talking about the second measure, isn't it?
Dario
Gainclone - why use large value decoupling capacitors ? ash_dac Chip Amps 11 20th August 2006 02:49 PM
Caps for digital decoupling?? imperfectcircle Digital Source 5 28th July 2006 05:39 PM
Decoupling caps(again) argonrepublic Parts 2 10th May 2005 10:32 PM
decoupling caps argonrepublic Parts 4 8th May 2005 10:20 PM
decoupling caps question audiokid25 Parts 6 28th October 2004 09:56 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
