Old 11th April 2003, 04:54 PM   #11
Philo is offline Philo  United States
Olle,
The whitepaper is online at http://www.national.com/ds/LM/LM3875.pdf. I also recommend going back through the "Not just another Gainclone" thread for suggestions and recommendations. There is way to much info there to be repeated in another thread.
Philip
"If you didn't make it with your own two hands, its not really yours".
Old 11th April 2003, 05:08 PM   #12
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Re: Gainclone help plz!!
Originally posted by TedPolzin
Hi I am having some problems with my attempt to build gainclones. I have sucessfully built 4 clones. I am also having trouble with others. I get full voltage on the output. This has happend with 5 chips. I an getting frustrated since they may be cheap but not that cheap. I have looked at the chips and have no idea why this happens. The bad ones are identical to the good ones. I take my time and it still does it.
Please do you have any ideas??
thanks
Ted
What exactly is the problem? You've built 4 amps that are OK and the other you've built are not working?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 11th April 2003, 07:18 PM   #13
Default Re: Re: Gainclone help plz!!
Ok I have built 4 that work fine (I later fried one .. but that was my fault.) I have also built 5 that seem to have full voltage on the output. I have no idea why. I follow the same building techniques and have double and triple checked all my connections but it seems a crap shoot whether it will actually work or give not. When I say full power on the output I mean with no signal it will give 15 volts on the output pin when I put a volt meter across the output. (from output to ground). I have no idea why this is happening and am hoping someone can give me some direction as to what I am doing wrong.
Does that make any sense?
Ted
Old 11th April 2003, 09:36 PM   #14
pinkmouse's Avatar
Default Re: Re: Re: Gainclone help plz!!
SNIP
Hi Ted
The only thing I can think of is that maybe you have a batch of dodgy chips. Do they all have the same lot number? I have built about a dozen amps using the LM chips, ( I am just in the middle of building another 5 channel system for a mate's HT system), and the only problems I have had were down to user error...
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 12th April 2003, 02:03 AM   #15
Hmm I may have solved it. I think some how my bench supply was causing it. I hooked it up to my amp power supply and worked good. Tried it with my bench supply and +15 volts. I also tried another one same result. Now I need to figure out what my bench supply is doing .
On another note what reisitor do I need for the mute on a 3886 with +-35 rails?
Ted
Old 13th April 2003, 02:41 PM   #16
Matttcattt's Avatar
i have made a mono gainclone (one channel) with the OPA548 and i looked at the datasheet and got the pinout. i have built this circuit (see image) and i get -20v (supply voltage) at the output. i am using a bench power supply so this could be the cause but i dont think so.
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 13th April 2003, 02:43 PM   #17
Matttcattt's Avatar
oops, forgot the image.
Freebird + Gainclone = "integrated" gainclone? bikehorn Chip Amps 9 5th January 2006 03:07 PM
JLH v Gainclone? Jezz-the-Fezz Solid State 5 12th December 2005 12:08 PM
Big gainclone steven344 Chip Amps 10 23rd November 2005 07:58 PM
Copyright ©1999-2013 diyAudio
