| Chip Amps Amplifiers based on integrated circuits |
I think I got the gainclone bug Digging on the web I saw that the jeff rowland concentra uses some concepts that are mentioned in this forum regarding the gainklones, like the use of LM3886 and battery supply. Taking a look at http://www.jeffrowland.com/review16b.htm we can see that: 1 - input is through a tranformer and an AD815 2 - output are 6 x LM3886 TI has an application ("Complete Audio Amplifier") where they use a OPA134 input opamp, that serves to make the treble and bass controls, and then a simple OPA548 (replaceable by the usual suspects). My question/thoughts are if these more elaborated designs can be better than the gainclone. And if there is a point in converting an unbalanced signal to balanced signal inside the amp to send it to the further stages. And if the transformer is necessary or the input opamp can do it. Miguel |
#2 | |
Hehehe. I like how their marketing literature tries to mislead people, referring to a power opamp as an "Intelligent Power Transistor with Gain" and implies that these devices are simply replacing the typical output transistors in an amplifier. 47 Labs has some laughable marketing verbiage too, but at least they call a spade a spade when it comes to the Gaincard being based on a power opamp.
As for converting an unbalanced signal to a balanced signal inside the amp, well, seeing as the Concentra uses a bridged output scheme, you need to produce a symmetrical signal to drive the two halves. As for the transformer, I'm not sure what you mean by the input opamp doing it. Not sure what the "it" is that you're referring to. An opamp certianly can't provide electrical isolation. It can't offer as good common-mode rejection performance from balanced sources without trimming of the output impedances of the source to make sure they're as matched as possible and it can't give you anywhere near the common-mode rejection that a transformer can when fed from unbalanced sources. I've been using power opamps in my own amps for over a dozen years. While the power opamps I've used have changed over the years, the basic configuration has always been input transformer/power opamp. It's worked well for me. My amps have all been just power amps though. However you could simply put a pot or swtiched attenuator between the transformer and the power opamp. However this would only work using the power opamp in non-inverting mode. Otherwise, the attenuator would need to be upstream from the input transformer. se |
#3 |
hi steve,
wouldn't you say that using a DRV134 from Ti as the input device, could be a very good idea...? perhaps JEFF ROWLAND is allready doing this in his poweramps - there is certanly no input transformer inside...? best regards, troels
#4 |
A transformer is still better...in some ways.
#5 |
This has already been discussed previously. I think R Jones owns a JR 3886 based amp and he used it as reference while working with the STK modules. Apparently this particular JR is not that great sounding. But i would imagine the sound is different and in some ways better than a gaincard. The multiple parallel devices will certainly improve drive of more difficult loads and generally bass quality. The bridging will further improve dynamics and bass as it solves problems of ground currents/psu well. Arguably the best way to implement bridging is using a quality transformer for the phase inversion. I think JR uses Jensen. So it may be a very valid exercise to improve on some sonic aspects of gainclone while hopefully not losing out on others (immediacy, microdynamics).
cheers peter |
#6 |
I guess the transformer we are talking about here would have to be something very well made, which means expensive. Wouldn't a nice pair of opamps costing 1euro or such do the same trick, feeding one in the + input and the other on the - input? I guess the feedback is different and would have to be adjusted.
#7 |
jeff rowland is using transformers in the concentra but NOT in the poweramps......
#8 | |
Transformers:
1. provide galvanic isolation, 2. are immune to some nasties that active devices are not (thanks to the laws of physics), 3. do not generate some nasties that active devices do (again, thanks to the laws of physics). Jeff Rowland does indeed use Jensen transformers. And yes, they are expensive, but this IS high end, right? However, active devices can sound good in this role. mlloyd1 Quote:
#9 |
there are no transformers in the new poweramps.......
#10 | ||||
5.suffer from histerisys of the magnetic material... 6.are sensivel to core saturation if they have a small DC across it... 7. are bandwith limited...
Jorge |
| Jeff Rowland Model 7 Please Help | rebank | Solid State | 2 | 13th February 2009 09:44 PM |
| Jeff Rowland Model 5 | itom | Vendor's Bazaar | 0 | 12th July 2008 02:06 PM |
| Jeff Rowland Model 1 | Sandor | Solid State | 0 | 18th March 2008 10:44 PM |
| pass vs jeff rowland | arthur | Pass Labs | 35 | 18th October 2006 05:29 PM |
| Jeff Rowland | ben goh | Analogue Source | 0 | 14th May 2005 06:04 AM |
