Old 6th January 2009, 02:07 AM   #1
bluegti is offline bluegti  United States
Default Need help with power supply
Originally I was going to build two mono-block amps in a separate chassis, but now I have decided to put both amps in a single chassis. I have two Avel Y236503 160VA 22V+22V Toroidal Transformers and a LM3886 Dual Mono Kit Contents from chipamp.com.
After looking at the Power supply configuration based off of a unregulated design by Carlos Filipe I believe that I should connect the primary and secondary wires as follows:
  • Blue/Violet twisted to 110V mains
  • Grey/Brown twisted to 0V mains
  • Black to AC1 on power supply board
  • Red to AC1-- on power supply board
  • Orange to AC2 on power supply board
  • Yellow to AC2-- on power supply board
I read Chip amp power supply - a beginners guide, but now I'm confused. I believe the configuration referenced above has two bridge rectifiers but I want to be sure.
  • Please confirm that I have my connections correct.
  • Do I need to implement the loop breaker circuit as descrived in the begninner's guide, or can I simply run a wire from the CHG (chassis ground) on the circuit board to a chassis ground point?
  • Anything else I should consider?
Thanks for you help... I'm almost done!
Old 6th January 2009, 07:56 AM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
If you have four rectifier diodes, then you have a single bridge, if you have eight diodes, then you have a dual bridge.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 6th January 2009, 11:16 AM   #3
Default Re: Need help with power supply
Yes.
You should use the wire. If that results in a ground loop, i. e. hum, then you can try to solve that with the loop breaker circuit.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 04:36 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Page generated in 0.07437 seconds (70.37% PHP - 29.63% MySQL) with 10 queries
