Logitech Z-5300 without remote
Old 6th January 2014, 05:16 PM   #11
ceteras is offline ceteras  Romania
Default Update 2014: remote pinouts
I have one of these boards on my desk and I took the time to study the connections to the remote control connector.
1. GND
2. Headphones 1
3. GND
4. Headphones 2
5. GND
6. +5V power to remote
7. GND
8. GND
9. GND
10. not connected (I think so)
11. STBY command from remote to system
12. MUTE command from remote to system
13. Spatial stereo command from remote to system
14. I2C SCL from remote to system (NJW1150)
15. I2C SDA from remote to system (NJW1150)
Pins 1,3,5 are analog ground. The other grounds are digital.
I don't know which Headphones signals is left and which is right.
Pins 11 and 12 go to the bases of two NPN transistors, so series limiting resistors are mandatory (10k should be fine). The bases of these two transistors are tied to +5Vcc on the system board through 20k resistors.
Tie pin 11 to GND to get the TDA power IC's out of standby. Leave open or to +5V for stand-by. The thermal sensor (normally closed connection) is connected between pin 11 and the base of the standby transistor. When overheat, it opens and the power ICs go to standby.
Tie pin 12 to GND to get the power ICs out of MUTE mode. Leave open or tie to +5V for MUTE On.
Tie pin 13 to GND to get the same effect as setting the swith on the back of the board to the "2ch" mode. In this mode, the rear channels are obtained from processing the two front channels (a sort of spatial stereo, they filter FR and FL then get the R-L and L-R signals which become the rear signals).
Pins 14 and 15 go straight to the system's volume and tone controller, NJW1150.
Its datasheet can be found on the internet, and I believe it's piece of cake to control with an Arduino.
I'm working on a small controller based on a PIC mcu (18F2550) because that's what I've got laying around.
Edit: I've just realized that the series 10K resistors are not needed because of the on-board pull-up 20k resistors. It would be best to use open-collector outputs to attack pins 11 and 12. Perhaps 13 too. Or better, use latching switches to GND.
Old 12th April 2014, 08:19 AM   #12
NonaSuomy is offline NonaSuomy
Hi ceteras,
How far did you get with your hacked board?
Any chance you could take pictures of the original pcb or any one else?
I attempted to see if I could fire bits at the sdl scl lines with an arduino with no success, I will post what I tried from your pin out there tomorrow.
0x08 //mute register
0x00 //unmute 0x01 mute
I tried putting both the stby and mute to gnd and +5v didnt seem to do anything as well.
The arduino crashes when i try to send to the i2c address of 68 (0x44) so not sure whats going on there tried to swap the wires and put a 4.7kOhm pullup resistor to 5v on both sdl/scl also didnt help. Hopefully that i2c volume chip isnt bad in my subwolfer. :/
Let me know if you have any updates.
Thank you.
Old 12th April 2014, 09:54 PM   #13
So I was unable to get a reading from the i2c Volume IC
So I soldered leads right to the pins of the NJW1150 Pins 16 SCL / 17 SDA
I was then able to detect the address of the NJW1150 which is (HEX 0x44) as said in the documentation (Binary 1001000) (Decimal 68).
Arduino Playground - I2cScanner
Scanning...
I2C device found at address 0x44 !
done
Here's my quick code that doesn't work for me but maybe helps someone in the future it's how I believe it should work. The code unmute's the NJW1150 waits 2 seconds, then changes the volume to max waits 2 seconds, then volume min wait 2 seconds, Repeat...
Code:
//Start Code Arduino Sketch Z-5300 SoundTouch Wired Remote Control.
#include <Wire.h>
//NonaSuomy
void setup()
  Wire.begin();
  Serial.begin(9600);
void loop()
  Serial.println("UNMUTE");
  Wire.beginTransmission(0x44);//(0x44) Device Address 68 Decimal
  Wire.write(0x08); //Mute Control
  Wire.write(0x00); //Unmute 0x00 Mute 0x01
  Wire.endTransmission();
  delay(2000);
  Serial.println("VOL+");
  Wire.write(0x00); //Master Volume
  Wire.write(0x4F); //“1001111”=-79dB
  delay(2000);
  Serial.println("VOL-");
  Wire.write(0x50); //“1010000”=MUTE:Default Value
  delay(2000);
//End Code Arduino Sketch Z-5300 SoundTouch Wired Remote Control.
I'm not sure I even understand how to power up the board I know its on as its putting 5-6V out of pin 6 +5V power to remote.
I put both:
to GND and no sound seems to come out.
Here is an image of the soldering from the arduino.
Blue wire goes to Pin A5 on the arduino (SCL) and white wire goes to Pin A4 (SDL).
I also have two 4.7KOhm pullup resistors to 5V on the SCL, SDL Lines.
I might put the scope on it later to see if Im actually changing anything on the NJW1150 but that's all I can muster for now.
Hope it helps!
Old 13th April 2014, 04:07 AM   #14
Cracked it! Works now was just me not understanding attenuation...
Wire.write(byte(0x00)); //Master Volume
Wire.write(byte(0x00)); //“0000000”=0dB (Full Volume-ish)
Also I soldered my pins backwards on my VGA header as to why I couldn't power on the AMP once I figured out that I finally heard a pop from the sub powering up when I grounded both STBY and MUTE, but not sure if I can still get an i2c connection from the back VGA header will try after I get some better code for dealing with the options of the chip.
So ecstatic right now!
I'll see if I can make a silly remote for fun, will share if I figure anything else out as if it wasn't for ceteras PIN OUT I probably would have thought it was impossible as I was finding no information on this unit besides people asking about replacements and NO the Z-5500 does not use I2C, the Z-5200 uses I2C.
I'll paste some brain dumps I was doing later I used a VGA port off an older video card that was detachable (header pins) as it has HDMI and DVI on the card.
Old 6th July 2014, 09:26 AM   #15
roxor08 is offline roxor08
Default Interested in results!
Hi! New user here with the same system as you have described here.
I, oddly have found a few things myself. But first a little background:
I acquired the z5300e system quite a while ago from a friend as a gift and I've recently started to "finish" my garage. As part of this job, I thought it'd be neat to wire the garage for surround sound, so using the 5300, I set to it.
Using RCA extensions, VGA extenders, wall plates, and a lot of sweat and time cramped in the attic, I finally finished wiring the entire system to place each speaker in its respective corner/center while creating a shelf for the subwoofer above the garage door. I intended to place the control pod near the entry to the house so I could power on the system when I enter the garage, and turn it off when I go back inside.
After doing all of this, and failing to power the control pod at the extended distance I started doing some research and found (like many have already) that VGA extenders cannot be used to extend the pot further from the subwoofer enclosure. That's damn annoying, but I figured I'd still attempt further.
In a funny set of circumstances (and ordering the wrong cabling) I picked up a gender changer I needed to connect the system. Here's a simple schematic of what I have going on:
Logitech z5300e-->F/F Gender changer--->M/M 1.5' VGA extension cable--->wall plate(F/F VGA coupler)--->50' M/M VGA cable--->wall plate(F/F VGA coupler)---->M/M Gender changer---->Control pod
So first off, yes I realize I have quite a few unnecessary joints in there (specifically the gender changers) but I wasn't very attentive when ordering the parts.....
Next, I thought I'd share some findings. In realizing my error, I had to make several (separate) purchases of equipment to complete my design. So, initially, to test everything (without the extension leg) I affixed the control pod to the sub enclosure above the garage door and cranked the volume to maximum. With my iPhone connected to the stereo jack (green) I adjusted the sub output until it fit my liking.
Once I received all of the necessary gender changers, I wired the system according to my design (above) and found that the system worked as I had designed with one exception. I had zero control with the pod. No lights, no power, nothing. This isn't the worst possible thing that happened actually because with the volume maxed out initially, I could control all of the sound with my iPod, albeit the control was linear. I didn't have subwoofer control, fade, or center control. Annoyed, I figured I'd just leave the control pod plugged in it's original spot above the garage door, and if I ever needed to adjust it, I'd have to close the garage door, get on a ladder, and make my adjustments....
However, I was still quite confused why the system worked *as if* the control pod was connected, yet didn't do execute any of the control features. So after some troubleshooting I found that the gender changer that I had connected to the VGA port on the subwoofer enclosure must have something to do with it. My theory is, that since the gender changer is simply a coupler (of sorts) it doesn't have an effect on the pinouts of the circuitry. The standard VGA cables I have though must (and my research indicates that they are the reason that it doesn't work) directly effect the dysfunction of the system.
This brings me to my final point and question. Is there something I can add, or remove from the VGA cabling to extend the control to the pod (in this case over 40' away)? I have yet to fully test the output/input of each lead. I am aware that there are several schematics of this diagram available on the net, but they are for the 5500 system :-(. I may just need to resort to taking apart the control pod cabling and mirroring it via the VGA cabling I already have routed in the sheetrock :-(.
That doesn't sound fun...
I know that the thread is specifically about running this system without the control pod, but I thought the bit regarding the gender changer connected could possibly help too!
Old 11th July 2014, 08:24 PM   #16
Jimmy154 is offline Jimmy154  United States
Jimmy154's Avatar
Default Also Interested in results!
I wish there was a way to bypass everything for each channel except for the amps.
I have a 6 channel output on my computer sound card.
But bypassing the remote is also a very good thing.
Old 28th July 2014, 01:59 AM   #17
wendle is offline wendle  Japan
Hi Jimmy154,
If you read my posts in this thread I have bypassed remote and feeding direct from my sound card. The computer is doing all the volume for separate channels and crossover for speakers and subwoofer.
Old 23rd September 2014, 09:31 PM   #18
TheExpertNoob is offline TheExpertNoob
@Wendle I am only seeing two connections going from the preamp to the amplifiers. What is the third wire for and do you have more pictures or a better picture of what the wires are actually soldered to.
Old 25th September 2014, 07:54 PM   #19
Jimmy154's Avatar
I also don't know where to connect anything.
I don't think we are that technically advanced.
Old 9th November 2014, 02:00 AM   #20
melsion is offline melsion
Hi, sorry for bringing up this thread again. I've got a z-5300 and it was working perfectly until a few days ago, long history short... the transformer went away. I'd like to repair it, but I haven't found a way to open the subwoofer and I don't want to break it just to see the transformer values, I can't test the output voltages because it's shorted.
Would you be so kind to tell me the voltages of the green-black-blue wires? That way I'd be able to find a replacement and attach it on the back of the amp.
Thank you very much in advance.
Logitech Z-5300 without remoteHide this!Advertise here!
Logitech Z-5300 Amp Connection Skavage Chip Amps 3 12th August 2017 04:57 PM
Logitech Z-5300: Amplifier has a bad satellite output spongebue Solid State 5 21st February 2011 08:46 PM
(Hacking the) Logitech Z-5300 pinouts? superxpro12 Chip Amps 2 23rd October 2009 03:02 AM
Logitech Z-5300 satellite driver TKESlinky Multi-Way 3 10th September 2005 06:21 PM
Logitech Z-5300 versus Klipsch ProMedia GMX jack_soltysik Multi-Way 10 14th August 2004 06:01 PM
Copyright ©1999-2017 diyAudio
