Old 4th January 2009, 09:13 AM   #1
kuldeepsingh's Avatar
Send a message via MSN to kuldeepsingh Send a message via Skype™ to kuldeepsingh
Cool Bridged 2XPA100 for Subwoofer, Plans
I wish to make a 200 W subwoofer amplifier using LM3886 in Bridgd and parallel configuration.
I made PCB layout for PA100 configuration. And using a signal splitter (Inverting and Non-inverting ) to run 2 PA100 modules in Bridged form.
The circuits and PCB is as shown. Before Etching i just want to make sure the circuit is OK, just want to get it checked guys..
Thanks.
AUdio Signal SPlitter - http://picasaweb.google.co.in/kuldee...79099025389842
PA100 Circuit - http://picasaweb.google.co.in/kuldee...79095145871522
PA100 PCB - http://picasaweb.google.co.in/kuldee...83031831745938
My Best LM3886 PCB layout
Old 4th January 2009, 09:43 AM   #2
audio splitter circuit.
The output offset from each of the opamps is not near zero.
The resistor values are all wrong to match resistances on the inverting and non-inverting inputs.
Fortunately you have specified a FET input opamp that has inherently low input offset current and this will reduce the output offsets.
For good bass the power amp should have a turnover frequency <=2Hz.
I would recommend that the preamp feeding it should be at least an octave below this, i.e. <=1Hz.
Your 1uF & 47K have F-3dB @ 3.4Hz.
3u3F or 4u7F would be better for a DC blocking cap.
Add RF attenuation to the input.
I see you have DC blocking at the power amp inputs. All you lose due to output offset is available voltage swing before clipping.
PA100 schematic.
Copy the National schematic recommendations and read the whole document to ensure nothing is omitted. Many of the optional features are not really optional and are usually omitted from the simplified diagrams. I don't like the Zobel being moved to after the L//R. I would rather see a separate Zobel for each chipamp. try reducing the 10r in the L//R to 4r or 5r, maybe even lower.
Add in the 0r1 resistors to help balance the outputs from the parallel pair.
Select the resistors to <0.1% matching. Absolute accuracy is not important, matching is very important. Consider adding DC offset servo for each chipamp just as National show.
Add RF attenuation at every input.
After you have added back in all the missing components, consider whether a BPA is worth all the bother and complication when better performance can be obtained with an LME489x0 driver chip and a separate output stage. Or just go fully discrete.
regards Andrew T.
Old 4th January 2009, 10:08 AM   #3
is this Circuit better than previous..
2. I am using matched resistors with .1% (checked using multimeter).
3. The placement of Zobal in this way reduced component count as well as simplifier PCB layout, but functionally it still maintains the stability due to loudspeaker cabaling effect.
Old 4th January 2009, 10:40 AM   #4
this will not work.
Read up on how opamps operate.
regards Andrew T.
Old 4th January 2009, 10:47 AM   #5
this will not work.
ya. thnx.. placed a resistor wrongly
this was the circuit which i initially had in mind. How abt this one.
Old 4th January 2009, 11:46 PM   #6
How about this solution for bridging?
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 5th January 2009, 07:56 AM   #7
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Or this simple one;
http://www.thatcorp.com/1600-series_...river_ICs.html
Best regards,
Ozgur
Old 5th January 2009, 10:58 AM   #8
CJ900RR is offline CJ900RR  Sweden
Or how about this: http://focus.ti.com/docs/prod/folders/print/drv134.html
Old 11th January 2009, 07:53 AM   #9
Default Modules are ready
aaha, the modules are ready,just working on power supply..
More pics
bridged amp please help Dan2 Solid State 5 27th April 2008 12:34 PM
Bridged (BTL) A75 Help please damacles Pass Labs 7 26th April 2008 01:34 AM
Plans for BIG 2x Ascendant Avalanche 15 subwoofer/TV stand BHTX Subwoofers 5 30th October 2006 12:42 PM
Adire Shiva 12&quot; subwoofer project plans sirius98 Subwoofers 13 9th November 2004 10:51 AM
bridged SOZ FBLEAGH Pass Labs 5 24th September 2001 01:32 AM
Page generated in 0.10427 seconds (81.24% PHP - 18.76% MySQL) with 11 queries
