| Chip Amps Amplifiers based on integrated circuits |
I'm contemplating stereo 3886 gainclone in stainless steel enclosure with toroid in the middle. With transformer in the middle I have ~2.5" from sides to which I'd like to attach Power chips. Any chance for hum free amp in this enviroment?
regards, l |
#2 |
That is a question of Trial-&-Error. As a rule of thumb there should be a minimum of 20..30 mm, which translates to 0.8..1.2". The more the better.
One advantage of toroids is their narrower stray magnetic field compared to other transformers. And there are examples, where toroids are used very near to the audio components without problems. On the other hand we have seen threads, where the transformer had to be put into a separate case, because it would couple into the audio signal at any distance. By the way, the original Gaincard uses the transformer in a separate enclosure.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 |
OK ! Thanks
That's what I've thought. It (the amp ) supposed to be a gift for a girl so less "boxes" the better. Regards, L |
#4 |
#5 |
Don't expect too much of shielding a transformer. At those low frequencies you need an extremely efficient shielding material like mu-metal, which is hard to get by and extremely expensive.
#6 | |
Oh, it has an effect all right. Anytime you put a conductive barrier between a magnetic source and an area you want to protect, there will be some reduction. It may not be 100% or even close to that but it beats doing nothing at all. I can say that if a quiet amp is important to you, every effort to reduce noise and hum are well worth it. |
#7 |
i agree. I've used a sheild between the psu section and the audio with success.
Trial and error is the way forward though. Better to build the chassis around the amp imo |
#8 |
Steampuck gainclone
#9 | |
Where's the heatsink going to go? |
#10 |
The stainless steel chassis is covered with riveted tick copper strips. I'll just screw chip amps to the flat alu plates and the plates to the sides od chassis and the whole chassis will be a heat sink. Should be enough .Original Gaincard doesn't seem to have excessive heat sinks.
Regards, L |
| PC Gainclone with 14V Toroid | Bassterror | Chip Amps | 5 | 28th February 2009 10:16 PM |
| where to buy toroid for gainclone amp in europe? | space-cake | Parts | 0 | 21st September 2007 11:44 AM |
| Want to purchase some gainclone Boards. | samsagaz | Swap Meet | 3 | 31st January 2007 10:00 AM |
| E-bay gainclone toroid? | kestrel200 | Chip Amps | 2 | 18th February 2006 03:24 AM |
| Two of Brian's LM4780 boards, one toroid | Russ White | Chip Amps | 1 | 27th January 2005 01:04 PM |
| Page generated in 0.10361 seconds (78.80% PHP - 21.20% MySQL) with 11 queries |
