Old 3rd January 2009, 08:13 AM   #1
Exclamation crazy DC offset LM386 amp
I built the MiniDisc.org headbanger amp about 2 years ago. This was my first amp and I still use it today for my PC. I decided to break out the meter and measure the DC offset.
Imagine my surprise when the meter read 4V! Yes FOUR VOLTS! From LO to OG and from LR to OG. WTF? This shouldn't be happening. The output has a 470uf cap on it.
This is the schematic.
http://www.minidisc.org/schem.gif
Does this value change when headphones are plugged in. Should I be measuring it with phones plugged in? I was just using a mini to mini connector and measuring from tip to barrel and ring to barrel.
I have had phones plugged into this thing and I haven't burnt up a set yet.
Old 3rd January 2009, 08:46 AM   #2
That is absolutely normal, because the amplifier is working from a single power supply. The output must therefore be at half rail voltage ~4,5 V, when no signal is present, otherwise you would not get anything out of it. In your case the DC offset is the deviation from the exact half rail voltage.
Don't worry about your amp or your headphones. The blocking caps will not let DC currents pass through.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 3rd January 2009, 08:48 AM   #3
mjf is offline mjf  Austria
Default headamp
when the headphones are plugged in the offset has gone i think.because there is no resistor at the output,so the cap has to be loaded with your headphones.
build in a resistor at the output(1kohm or so).......
regards...........
Old 3rd January 2009, 09:34 AM   #4
Default Re: headamp
Originally posted by mjf
....build in a resistor at the output(1kohm or so)..................
10k or even 100k would add less loading to the chip output.
regards Andrew T.
Old 3rd January 2009, 07:48 PM   #5
Few, that eases that fear! It makes since too. Thanks guys. I did measure it with headphones plugged in and got zero V.
Lm386 frenchie29 Chip Amps 10 27th April 2009 09:32 PM
Need some help with DAC and LM386 zhane Chip Amps 6 21st April 2008 07:38 PM
lm386 poweramp prorms Solid State 4 23rd May 2006 07:50 AM
LM386 but on AC? tubbytwo Chip Amps 6 29th November 2004 12:38 AM
DC offset like crazy... OPA541- HELP! trespasser_guy Chip Amps 12 23rd June 2003 08:49 AM
Page generated in 0.07610 seconds (74.97% PHP - 25.03% MySQL) with 10 queries
