Old 2nd January 2009, 10:46 AM   #1
Default new to the forums and new to chip amps
This is my first post here on the DIY Audio forums and I am about to build my first Chip Amp.
I have been looking at all of the great designs on this forum as well as others and was wondering what I would do about an enclosure. I have become friends with a guy that just opened a local audio repair shop and he just gave me 3 dead amps with chassis that will be perfect. Plus a lot of good parts in them like transformers, switches, and terminals.
I just ordered the dual mono LM3886 boards from BrianGT. I didn't order the complete kit because I buy components for a living and have access through my suppliers for next to nothing.
Before I get started, I have a couple of questions (actually looking for opinions) on a few things.
1) Stereo vs. dual mono? Any opinions on which design is better or worse?
2) Resistor types? Has anyone used the Dale/Vishay RN series resistors? I have access to almost any value available, and I believe these are better quality than the
ones that are included in the chipamp.com kits. They are metal films with 25 or 50 PPM and 1% tol.
Old 2nd January 2009, 11:40 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
Dual mono is always the best if you have the opportunity.
Ordinary metal film resistors will do if you'll ask me. Temp co 25 or 50 ppm/deg doesn't matter.
If you'll feel better by using other types of resistors, go for it.
/Per-Anders (my first name) or P-A as my friends call me
Old 2nd January 2009, 06:21 PM   #3
ensure you never run any audio resistors above half their maximum heat dissipation rating.
Preferably keep them below 25% of rating and in the NFB route probably aim even lower.
regards Andrew T.
Old 2nd January 2009, 07:47 PM   #4
mjf is offline mjf  Austria
Default dual mono
stereo is often cheaper and simplier to do.
dual mono gives the better channel separation and so on(if well done)
greetings..........
Old 22nd January 2009, 03:39 AM   #5
I decided on dual mono and have the 2 amp boards built and 2 PSU boards built.
I got the 2 Avel 160V 22-0-22 toroids, got the chassis ready and have a few other needed components.
I am ready to tackle the mains wiring, but like most newbies, I want to be sure I got it correct. How does this look?
The switch is already mounted in the case so I was going to use it. It is an SPST illuminated rocker switch. My understanding is the way I show it wired, the switch should work but will not light up. My question is, how to wire it so it lights when on?
Old 22nd January 2009, 05:36 AM   #6
First, have a look at the switch. Often there is small diagram on, where the right connection is shown. One of the pins is the switch's input. That is, where the wire from the fuse goes. One is common to the switch and light, i. e. output to transformer. And the third is the other leg of the light, which connects to N.
If there is no diagram, you can measure it. Set a DMM to Ohms and measure from pin to pin. Two pins will have either no resistance or nearly 0 Ohms. That is the switch, and if you toggle it, the resistance should jump from 0 to none and back. Then you need to find the matching pair that shows a resistance that is significantly higher than 0 Ohms. That is the light.
Before you do that however, make sure that the switch and the light are rated for your mains voltage. In an increasing number of cases the manufacturers use their main switches on the secondary side, because that makes them cheaper. Then they are not rated for mains voltage and current.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 23rd January 2009, 01:27 PM   #7
Thanks for the info.
The switch wasn't marked so I figured it out with the DMM. The switch was used in the amp that I am using the case from and it was wired to the primary side in that amp. It's rated 20 amp - 125V / 16 amp - 250V, so it should be fine.
So knowing where the pin for the light is on the switch, the wiring should look something like this, correct? Does the rest of the wiring look correct?
Any suggestions from anyone on doing anything differently?
Old 23rd January 2009, 01:33 PM   #8
That looks correct.
Old 23rd January 2009, 02:00 PM   #9
do you use double pole switches for mains OFF/ON?
regards Andrew T.
Old 24th January 2009, 11:40 AM   #10
This is a single pole switch that was used in an existing amp.
So many chip amps ? Buzzy Chip Amps 6 31st August 2007 08:29 AM
New to Chip Amps skidave Chip Amps 14 28th July 2007 06:15 PM
Has anyone compared the Chip amps against Class T amps? soongsc Chip Amps 3 24th July 2005 11:50 AM
chip amps for ESL's? Few Chip Amps 3 30th April 2004 11:30 AM
Page generated in 0.11501 seconds (80.24% PHP - 19.76% MySQL) with 11 queries
