Old 1st January 2009, 03:09 PM   #1
jaste is offline jaste  Sweden
Default Buffer for TDA7266?
Hello! I´m building a little amp for my parents using the TDA7266. Can anyone recommend a nice op amp for a buffer with single supply of 12 volts? Been thinking about the NE 5532 but wanted to hear your opinion.
Thank you for your help!
Old 1st January 2009, 08:06 PM   #2
mjf is offline mjf  Austria
Default ne5532
it will work with the (bipolar) 5532.many outputstages of cdplayers use it.another ic is the lf353(jfet) with equal pinconnection -you can change it for listeningtests each other.
essential:the purity of voltagesupply,ic`s are sensitive to supply noise and so;e.g. two voltage regulators in series,one near by the pins of the ic..............kind regards........
Old 1st January 2009, 10:37 PM   #3
Could someone maybe recomend a schematic for the NE 5532?
Old 2nd January 2009, 10:46 AM   #4
Default 5532
datasheets you can find on: datasheetcatalog.com
write in simply: 5532 -and there are all sheets.
greetings..............
Old 2nd January 2009, 10:46 AM   #5
Default ne5532
or better write in: ne5532 and click : search
regards...........
Old 2nd January 2009, 02:49 PM   #6
I was more thinking of a circuit where the ne 5532 was used. As an buffer that is.
Old 2nd January 2009, 05:24 PM   #7
Default 5532
here is a classical buffer amp(with optional volume control).most of the parts are free to choose.
Old 2nd January 2009, 06:33 PM   #8
Juergen Knoop's Avatar
you don't need a buffer!
TDA7266 suggestions jaste Chip Amps 2 3rd September 2010 01:49 AM
Diamond Buffer - Super Buffer peranders Solid State 34 16th May 2010 01:46 PM
Near ZERO IMD buffer amp wenye Solid State 37 20th April 2009 07:50 AM
buffer TUBESMAN Solid State 4 22nd October 2008 05:32 PM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 06:50 AM
Page generated in 0.08606 seconds (76.24% PHP - 23.76% MySQL) with 11 queries
