Old 29th December 2008, 04:50 AM   #1
JackM11 is offline JackM11  United States
Default Question on Ne5532 + 3886 amp on Ebay
I bought one like this for $30 to play with:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=190276589462
I use it with my old Rotel preamp and it sounded quite clean and detailed. However, there were high freq hiss when I listened close to the tweeter. Also the gain of this amp is a bit too high as I needed to set the preamp volume quite low.
Can anyone explain the reason for the NE5532? Or I should better bypass it and just use the 3886?
I attached the schematic from the seller. It shows a LM833, not the NE5532 so I guess the schematic is not current but close enough.
Thanks in advance for any suggestions.
Old 29th December 2008, 06:47 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
The LM3886 has actually noise and if you put your ear very near the tweeeter any power amp have noise!
NE5532 => much hifi for the money
The opamp may be used as buffer and as DC servo.
One thing you should be aware of is the non-optimal ground in the star ground. It seems that the smoothing caps will have an influence on the signal ground.
It's worth noticing that Italy is a not prefered country. I have never experienced that it takes a long time for goods to arrive Italy.
/Per-Anders (my first name) or P-A as my friends call me
Old 2nd January 2009, 05:02 AM   #3
sangram is online now sangram  India
NE5532 is noisy, not much way around it, except a volume pot between it and the 3886. I use one right now after an AlienDAC to bring up signal level to a respectable number, but soon to be replaced with better chips (LM4562) and circuitry. As it is it's unusable due to the noise unless the pot is turned down halfway.
Old 2nd January 2009, 10:02 AM   #4
Juergen Knoop's Avatar
either a faulty IC or there is something wrong with your circuit/implementation.
regards
Old 2nd January 2009, 11:42 AM   #5
peranders's Avatar
Originally posted by sangram
NE5532 is noisy....
NE5532 is one of the more silent opamp if you don't have signal sources with Mohms as output impedance.
Old 6th January 2009, 06:58 PM   #6
I guess they use the opamp as a preamp. have you tried it without your preamp?
Old 6th January 2009, 07:09 PM   #7
Hi becki200,
thanks for your suggestion. Also thanks everyone who gave me a suggestion.
I used a preamp because I don't have a proper volume control for the kit. With a preamp the gain is a bit too high and perhaps this is one reason why I can hear more noise.
Anyway, this small $30 investment allows me to find out a chip amp potential and I am glad I did it. By the way, I have a small heatsink on the chips and they run quite hot but no problem thought, which is good. At least the amp works.
Jack
Old 6th January 2009, 07:49 PM   #8
mjf is offline mjf  Austria
hello.
cannot find a schematic.
little upgrade possible: ne 5532ap(tex.instr.) or ne 5532an(philips).
greetings................
Old 6th January 2009, 07:57 PM   #9
Hi Jack, buy a cheap pot (for example 2 x 100 kOhms) and connect a CD Player or any outher source directly to the amp. If you dont know how to connect it i could draw aschematic for you
Old 6th January 2009, 08:51 PM   #10
The schematic file size was bigger than the 100k limit before. I reduced the size and try again.
"Yuanjing" Gainclone 3886 - eBay amazing value ? gainphile Chip Amps 520 18th April 2012 12:07 PM
Newbie parellel 3886 speaker impedence question 2004ex Chip Amps 5 16th April 2007 07:26 PM
Buffered amplifier question ! (2134, 3886) -_nando-_ Chip Amps 3 24th June 2006 09:58 PM
3886 Transformer wiring stupid question thermonuclear Chip Amps 2 16th September 2005 05:38 PM
Brain GT 3886 PS question lgreen Chip Amps 10 5th April 2005 08:06 PM
Page generated in 0.10569 seconds (77.66% PHP - 22.34% MySQL) with 11 queries
