Strange buzz in only one channel
Old 20th December 2008, 04:34 PM   #1
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Default Strange buzz in only one channel
Hello,
I'm facing a strange problem.
I've just assembled a dual mono kit from chipamp.com and it sound great!
But only one of the channels, the right one, is very sensible to what is attached to elettric plant.
e.g if I leave on the solder station only the right channel makes a lot of noise, the left one is deadly silent... same thing when you switch on or off lights: only right channel is sensible!
Someone has any idea about it, what to check?
Thanks in advance
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref FE 12th GB is open
Old 20th December 2008, 06:05 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
With these being kits, the most likely fault will be a badly soldered joint somewhere. There isn't much else to go wrong.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 20th December 2008, 07:26 PM   #3
Reality first!
I've redone all solder joints in the PSU an amp boards but the buzz still there...
Dario
Old 20th December 2008, 07:27 PM   #4
Nuuk's Avatar
Is the buzz only there when the amp is close to the soldering iron?
Old 20th December 2008, 07:42 PM   #5
Ted205 is offline Ted205  United Kingdom
Ted205's Avatar
my guess would be a earthing issue.
Are you using a star ground scheme ? are all the ground leads the same length ?
Does the right channel work ok when the left channel is removed (power & ground leads)? What happens if you swap the modules?
Old 20th December 2008, 08:40 PM   #6
Reality first!
No, the amp is not close to the soldering iron.
Only branched ad turned on
Same thing happens with lights or when refrigerators starts compressing but in this case no buzz but pops.
Only to the right channel!
No, in this moment the amp is still 'naked' and if it would happened to both channels I would have considered a grounding issue but the left channel is deadly silent and doesn't seem affected from either soldering iron, lighst or refrigerator!
Now amp is configured in dual mono (dual amp, dual PSU and dual transformer) but yesterday was connected with both amps and a single PSU and single transformer and the problem was the same...one channel ok, the other 'sensitive'.
I'm confused...
Dario
Old 20th December 2008, 11:50 PM   #7
Reality first!
Well, I've surrended.
Buzz doesn'stop, the other channel stopped working!
Amp modules gone in the trash bin, I hope I'll be more lucky with MyRef...or maybe the next Gainclone (I've saved PSUs).
Thanks to everybody tried to help.
Dario
Old 10th January 2009, 07:37 PM   #8
Reality first!
Default For whom could be interested I've found the problem! :)
I've buyed two pcbs more and rebuilt the chipamp's Gainclone and that same strange problem reappeared, in the same channel, the Right one!
But there was also a new problem: no way to have dual mono!
If both amps were connected to one single PSU they worked, otherwise the right channel made only buzz!
The only things that have not be changed are:
RCA Connectors + theirs cables
Binding Posts
PSUs
Transformers
Well I've swapped RCAs Left <-> Right and the problem moved to the left channel!
So it was a RCA connector overheated...
Changed both RCA and now it works quite fine, also with solder station switched on...
I hope that this could be helpful for someone else!
Dario
Old 11th January 2009, 11:07 AM   #9
R.I.P.
can you post a pic of your set up?
and the schematic of both PSU and Amp?
regards Andrew T.
Old 11th January 2009, 12:58 PM   #10
Reality first!
My setup is simply based on Chipamp.com PCBs so the schematic can be found on their website.
The components used are:
Panasonic FC & Evox-Rifa MMK (PS Decoupling)
Nichicon KG Gold tune (Main PS Reservoir)
Takman REX Resistors (Signal Path)
Philips/BC PR02 (Power resistors and Zobel)
Wima FKP2 (Snubber)
Evox-Rifa PHE426 (Zobel)
Selectronic R-Core 120VA Transformers
Solid Core speaker cable
Tasker Shielded Cable
Chinese 'High-End' Binding posts
Chinese 'High-End' RCA connectors (substituted by a PCB RCA Connector from trash...)
Some photos:
Dario
Strange buzz in only one channelHide this!Advertise here!
NAD 310 buzz in left channel Rodmunch Solid State 2 21st March 2009 11:58 PM
strange distortion on one channel of cd player Luke Digital Source 13 18th December 2008 05:43 PM
K-12 kit, buzz in R channel mnr102 Tubes / Valves 12 20th February 2008 05:35 PM
Melos triode and computer as source: BUZZ BUZZ BUZZ zigo3 Tubes / Valves 4 28th November 2007 02:11 AM
strange noise from right channel keyser Everything Else 15 2nd May 2005 10:14 PM
