Two rectifiers
Two rectifiers
Old 18th December 2008, 10:55 PM   #1
raypalmer is offline raypalmer  Canada
raypalmer's Avatar
Default Two rectifiers
I can't find it... can anyone help me, I need a diagram or explanation as to how to utilize both rectifier boards on my audiosector 3875 amp, off of my single dual-secondary toroid (non-centre tap).
Old 19th December 2008, 08:14 AM   #2
audio1st is offline audio1st  United Kingdom
audio1st's Avatar
It should be something like this below. Colours may be different with your transformer.
Old 19th December 2008, 08:38 AM   #3
col is offline col  Australia
col's Avatar
This is how I usually do it:
http://sound.westhost.com/project04.htm
col.
http://www.minirig.org.au
Old 19th December 2008, 08:43 AM   #4
Dr.X is offline Dr.X  United Kingdom
From what I have read over the last couple of weeks on this forum, I beilieve there is the potential for some hum problems with that 'paralleled' set-up and that you should ideally use one board per transformer (so two boards = two mains transformers, i.e. dual-mono).
Try Peter's specific thread... Gainclone Kit
HTH.
Old 19th December 2008, 09:57 AM   #5
project04 directly connects both Audio Grounds to Power Ground. This will give rise to excessive hum and buzz with multi-channel amplifiers with many setups/interconnects.
The dual rectifier gives the option to keep each channel's Audio Ground separate from all others. The down side is that a disconnecting network is required for every channel to take fault current back to Safety Earth.
Monoblock outperforms all others in my experience.
regards Andrew T.
Old 19th December 2008, 10:04 AM   #6
col's Avatar
Iv'e used the ESP project4 setup with several amps I have built using Hypex modules the audio GND doesn't go to power GND. It works fine and I have never experienced any hum.
col.
Old 19th December 2008, 10:14 AM   #7
Originally posted by col
Iv'e used the ESP project4 setup with several amps I have built ............................. the audio GND doesn't go to power GND.
could you define what "your" Audio GND is?
regards Andrew T.
Old 19th December 2008, 10:18 AM   #8
col's Avatar
I think you should pretty much be able to see all the connections here:
http://pix.minirig.org.au/main.php?g...geViewsIndex=1
I think my "audio GND" is the - terminal of the speaker :0
Is yours the GND of the amp module?
Haven't had any bad hums though.
col.
Old 19th December 2008, 10:29 AM   #9
it looks like the white wire is the centre tap to one PSU.
The black wire looks like a link from PSU1 PGnd to PSU2 Gnd.
The two Grn/Yel wires seem to connect the both PGnd1 & 2 to Safety Earth.
How do Signal GND and Speaker GND and PCB GND connect?
regards Andrew T.
Old 19th December 2008, 10:38 AM   #10
col's Avatar
Maybe because the Hypex amps have balanced inputs and the signal GND doesn't touch the case GND the project4 dual rectifier setup works?
The black wires that are the centre tap are the module GND, this connects to the case GND/earth.
I don't think they do, they seem all separate, unless it takes place inside the PCB.
col.
Two rectifiersHide this!Advertise here!
UCD 400 - Rectifiers kephaudio Class D 1 21st May 2005 07:06 PM
How many rectifiers? Valverine Tubes / Valves 6 15th February 2004 03:00 AM
Rectifiers for the GC elizard Chip Amps 70 23rd January 2004 11:38 PM
6.3V rectifiers.... Guiness Tubes / Valves 7 14th April 2003 08:24 PM
Copyright ©1999-2017 diyAudio
