Old 12th December 2008, 04:02 PM   #1
Ulew is offline Ulew  Sweden
Default Whose layout is this?
Hi!
A while ago I found this layout here, but now I don't know where!
Who have done it and does it work?
Old 12th December 2008, 04:43 PM   #2
ratza is offline ratza  Romania
ratza's Avatar
It's mine, it works from last year until now. If you need any other information, I will be happy to answer.
Any solution is a compromise.
Old 12th December 2008, 05:39 PM   #3
lineup is offline lineup  Sweden
lineup's Avatar
Is that PCB layout a bottom view?
lineup
Old 12th December 2008, 07:14 PM   #4
ratza's Avatar
Actually this is the view from EAGLE. The files were posted already here:
http://www.diyaudio.com/forums/showt...26#post1570826
Old 12th December 2008, 08:32 PM   #5
Super!
Actually, I've already used your design to make a board, but I haven't put it together beacause I don't know if i it works, but now I know, so I'll carry on with it!
But what does the power resistor do? I haven't seen it on other boards, I think!
And one question about the LM3886T, non-isolated, can I put it on the heatsink without isolation as long as the heatsink isn't connected to something, or do I short it if I do so?
Old 12th December 2008, 08:34 PM   #6
lineup's Avatar
It is a 'mirrored view'.
So my guess was right. The PCB posted above should be a view as seen from the bottom side of the PCB.
Where the tracks are, but not the components.
lineup
Old 12th December 2008, 10:02 PM   #7
Greg Erskine's Avatar
Hi lineup,
Not mirrored, it is a view looking from above.
regards
Greg Erskine
Old 13th December 2008, 04:49 PM   #8
Nico Ras's Avatar
Originally posted by Greg Erskine
Hi lineup,
regards
I think you should do a mirrored print for those who do not understand and use an iron and laser print.
Old 14th December 2008, 02:30 PM   #9
ratza's Avatar
That resistor is a 10ohm/3W which has 10 turns of 1mm copper wire. My boards are using the non insulated but my case is made out of wood. If the heatsink doesn't touch any other connected metallic part, it's fine.
For those who use press'n'peel: don't print the view in mirror, print it exactly how it's in EAGLE. Leave only pads, bottom and dimension in view then at print options choose "Solid" and "Black"
Old 14th December 2008, 02:33 PM   #10
Okay!
Then I'm good to go! Hopefully the amps are done pretty soon and then I'll show them here!
Eagle vs. Sprint-Layout for PCB design/layout hollowman Parts 9 9th July 2011 04:34 AM
pcb layout jamesrnz Power Supplies 0 9th March 2008 12:42 AM
help for a PCB layout pencoat Parts 0 4th October 2006 01:52 AM
is my PSU layout OK? tinkerbell Solid State 26 31st March 2005 01:02 AM
Possible GC layout? lazyfly Chip Amps 4 22nd August 2004 04:28 PM
Page generated in 0.11367 seconds (73.61% PHP - 26.39% MySQL) with 11 queries
