The new "My Ref" Rev C thread
Old 21st July 2009, 02:56 PM   #821
troystg is offline troystg  United States
troystg's Avatar
Originally posted by mhconley
OK - I have it wired correctly. Thanks Jericoh & Troy.
Should the 15 watt bulb in my dim bulb tester be glowing when only the transformers are hooked up? (Power leads are not plugged into the boards.) It is lit very dimly.
Martin
I use a variac and volt meters so I can't answer...
However I think Andrew is doing a WONDERFUL job advocating safety through the dim bulb tester. Saving more people to be able to participate in DIY.
Thank you Andrew..
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 21st July 2009, 06:33 PM   #822
mhconley is offline mhconley  United States
mhconley's Avatar
Thank you Andrew..
I agree - thanks, Andrew.
Here is a picture of the dim bulb tester I built in less than 15 minutes for just over $20:
Martin
Old 23rd July 2009, 01:47 AM   #823
mhconley's Avatar
I received the heatsinks today. Thanks, Troy!
I mounted them using the supplied shoulder bushing, insulator and some artic silver and tested each board separately.
Both boards seem to be working. The relays click and the LED lights. I measured these output voltages with the input shorted:
Board 1: 0.1 mVAC / 0.4 mVDC
Board 2: 0.1 mVAC / 0.2 mVDC
In the next couple of days I plan to mount them in the beginnings of my chassis, hook up the "DACT type" pot I picked up on eBay, fire up my trusty SCPH-1001 PS1 CD player and play them through a pair of speakers.
Martin
Old 26th July 2009, 02:09 PM   #824
jonclancy is offline jonclancy  United Kingdom
Thumbs up Yup - They're Grrrrreat!
Hi All,
I finally finised two channels of MyRefC and tested them. All seemed OK, and not misbehaving on a spare speaker, so I put them into the main system. As Uriah said to me, the Lightspeed has no trouble driving these amps. My AYA DAC sounded brilliant and the bass from the IPL S3TLM Transmission Line speakers was room-shaking on some tracks. Overall, they are a superb amp, and suit my system well. I socketed the relevant caps, but haven't rolled any yet. The heatsinks barely get warm, even after prolonged high volume playing.
I get a bit of hum, but that's not surprising given they're not cased etc. One think I did find on one amp is that the DC Offset was wandering up and down when I measured it. One of my amps has since reduced it's output and I suspect an misbehaving LM318. I'll build my other two channels and have a look at them all on the 'Scope - the op amps are socketed, so it'll be an easy swap with a new part.
Overall, I'm delighted!! Many thanks to Mauro, Peter and Uriah for all their hard work in making this great amp available to us!
Cheers
Jon
Old 26th July 2009, 02:26 PM   #825
udailey is offline udailey  United States
Passive Aggressive
Jon,
Nice job man! Dont forget you can remove the DC blocking caps if your DC offset is low. I did some more reading on that and found that less than 100mV is fine but that above 50mV starts to effect quality of sound. How much I have no clue.
So where did you get those beautiful toroids?
Really nice toroids.
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 26th July 2009, 02:43 PM   #826
They are super, aren't they??
225VA, encapsulated and best of all, cheaper than Farnell by a long shot!!
http://uk.rs-online.com/web/search/s...uct&R=223-8831
Build quality is superb and they are very, very quiet!
I'll be getting a couple more when funds allow, so each of my 4 channels is truly monobloc!!
Cheers
Jon
Old 26th July 2009, 04:21 PM   #827
Passive Aggressive
Cant get the encapsulated kind in 120V Would have to get double the secondary voltage and double the amperage on primary and secondary for the encapsulated.
Uriah
Old 26th July 2009, 08:52 PM   #828
quadtech is offline quadtech  India
Folks,
What is the acceptable DC offset on these amps? What is the typical offset?
Last I checked, I was getting roughly 4mV on each channel.
How do I tweak them to reduce the offset?
TIA
Prasad
Old 26th July 2009, 09:12 PM   #829
Passive Aggressive
4mV is exceptional. You could only get 4mV lower.
Uriah
Old 27th July 2009, 11:01 AM   #830
Lightbulb DC Offset
Speaking of which, I measured my amps at the output, but with the input unshorted (or connected to source). I recall shorting input to ground being mentioned. A Google search wasn't that helpful as I found advice exactly as I did.
Clarification gratefully sought, please!!
Cheers
Jon
The new "My Ref" Rev C threadHide this!Advertise here!
The "What slogan would you have if you were a high-end audio company?" Thread. Spasticteapot Everything Else 118 27th September 2011 04:31 AM
Original ECL86 "Baby Huey" thread jkeny Tubes / Valves 14 23rd November 2009 08:35 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 08:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 05:16 AM
