The new "My Ref" Rev C thread
Old 1st May 2009, 10:33 PM   #641
ClaveFremen is online now ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally posted by pinkfloyd4ever
you mean the differences between DC coupled and using a Mundorf?
No, the difference is huge between the vanilla MyRef and the modded one.
I'm not talking of night and day differences but is last 5% that makes the difference...
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 2nd May 2009, 04:42 AM   #642
Bengali is offline Bengali  United States
Hi Guys,
Thanks Uriah and Peter for the my ref C pcb's.
I've built up a stereo version with a 20V 200VA antek.
I'm using 1uF k42y PIO's.
First power up, no smoke :-) I get about 1.2mV and
around .50mV on the outputs.
They are hooked up to a pair of Maggie MMG's.
Pre amp is aikido 6SN7. Originally I'm using a mini-Aleph.
The Aikido and Mini-Aleph is a wonderful combination
to my taste.
okay, the my ref C, initial thoughts, the high's a very tinny,
women's voices have that sharp raspy sound. for movies,
it's not as bad but does not seems balanced overall.
I'll let it break in for while and listen later. Sorry, I'm
not trying to stir up anything, just my perception of
how it sounds compared to the mini-A.
it's definately a step up from the standard gainclone I've
built.
Old 2nd May 2009, 06:32 AM   #643
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Bengali, what speakers are you using? If DIY, do you have zobels for the tweeters?
Hear the real thing!
Old 2nd May 2009, 07:06 AM   #644
Hi Soongsc,
I'm using Magnepan MMG's.
I'm built it per the schematic/bom used here in these posts.
thanks.
Old 2nd May 2009, 08:14 AM   #645
Tony X is offline Tony X  France
Tony X's Avatar
To me if anyone is going to mod this MyRef you HAVE to remove C13 and put a wire in place of it then measure for DC. If it is still acceptable this is probably the best change you can make
Hi Uriah,
Do you measure with everything connected, input and load?
What would you consider acceptable DC level?
Parfois, martyr lassé des pôles et des zones
Rimbaud - Le bateau ivre
Old 2nd May 2009, 09:08 AM   #646
soongsc's Avatar
Originally posted by Bengali
Hi Soongsc,
thanks.
I did some search, and it seems that these have 6 Ohm impedance, and are not very effecient. Wonder if the transformer is not big enough.
Old 2nd May 2009, 12:51 PM   #647
Reality first!
Bengali, I think you're right.
Thanks to my socketed MyRef I've just restored it to the initial state (FMs, BQs, bypasses and so on) and bass is bloating, sound is thick but highs are tin, harsh and too much, soundstage is wide but deepness is flat.
I've then started reapplying all my mods starting from the last: C32
Wow on the vanilla MyRef this single mod has a big effect on bass!
All others mods made also their magic but C32 already fixed some things previously fixed by others mods (mainly bass ones).
With all mods and FMs as elcos it sounds good but with the Silmics is much better.
I've then reverted to vanilla and after to totally modded:
they're two different beasts, for sure!
Little or no harshness, a granitic bass, more harmonics and reverb, deeper sounstage.
Dario
Old 2nd May 2009, 11:28 PM   #648
Hi Dario,
you described it 100% correctly :-) I was not sure how to put it in words.
So changing the C32 150pF feedback cap from an AVX
to WIMA really made a difference?
I could give that a try on my next mouser/digikey order.
I'll go through your list of mods later and see what I can tweak.
Thanks for taking the time and sharing your efforts!
Old 3rd May 2009, 02:53 AM   #649
troystg is offline troystg  United States
troystg's Avatar
Hi Dario,
Thanks for taking the time and sharing your efforts!......
Absolutely!! I appreciate all the work you did on the testing.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 3rd May 2009, 03:27 AM   #650
Reality first!
Thanks to both
Yes Wimas FKP2 in C32, at least for bass, make a clear difference and add some harmonics too, particularly with FMs.
Every feedback on mods is welcome
Dario
The new "My Ref" Rev C threadHide this!Advertise here!
The "What slogan would you have if you were a high-end audio company?" Thread. Spasticteapot Everything Else 118 27th September 2011 04:31 AM
Original ECL86 "Baby Huey" thread jkeny Tubes / Valves 14 23rd November 2009 08:35 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 08:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 05:16 AM
Copyright ©1999-2017 diyAudio
