The new "My Ref" Rev C thread
Old 25th February 2009, 11:05 PM   #231
schro20 is offline schro20  United States
schro20's Avatar
Default C9 and C21
Dear Dario,
than you for posting your observations. Why are C9 and C21 so important? I would expect C13 to be the most important...
I will try your experiments. But first I have to build a second set (I need to compare back and forth otherwise I can't tell what's going on). But before I do that, I have to put together a nice case for my first set... You'll get a kick out of this: I ordered one of those cases you used. I happened to be in Germany last weekend and had them mail it to me there and then took it back in my luggage. Did you use any more heatsinking than just the side walls themselves?
peter
Old 26th February 2009, 01:18 AM   #232
madisonears is offline madisonears  United States
Dario,
Thanks for the capacitor testing results. You put those sockets to good use!
Do the C9 Elna's fit onto the board without too much trouble? It's hard to tell their relative size from your photo. They look to be similar size to the FM's.
Have you decided on a C13? I put a 1.5uf Bennic metalized poly cap in there, and it sounds a bit dull with loose bass. I have some other caps on order now.
Peace,
Tom E
Old 26th February 2009, 01:35 AM   #233
samsagaz is offline samsagaz  Argentina
well, really need some help to try to fix the amps, i searched the forum and i see some other guys with similar problems, will try to recompile info about my fault.
Old 26th February 2009, 02:43 AM   #234
marc brown is offline marc brown  United States
marc brown's Avatar
Default Re: C9 & C21 Caps comparison
Originally posted by ClaveFremen
I'm still asking myself why TP swapped MKS2s with BQs...
Well, they are 1/5 the price.
Old 26th February 2009, 03:01 AM   #235
R1 and R4 are really HOT is that normal?
I found some thread where i see that these 2 resistors come HOT, but someone recommend using 3W instead 1W Resistor.
All of you are using 1W? No problems with the resistors?
Old 26th February 2009, 03:06 AM   #236
troystg is offline troystg  United States
troystg's Avatar
My apologies, today was just a VERY busy work day and I did not get to look at the pictures for lunch ( I didn't take a lunch).
I promise to look at them tomorrow and see if I can find anything.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 26th February 2009, 03:31 AM   #237
schro20's Avatar
Dear Samsagaz,
if you check the BOM (see post http://www.diyaudio.com/forums/showt...84#post1755284) you will see that we actually put 2W resistors in there just for good measure. And, yes, they are expected to get hot which is why they are off the board.
peter
Old 26th February 2009, 04:36 AM   #238
well, i will drop the boards to the trash, im really deseseperated, 4 Boards Build 1 works 3 NO
Btw, have any others in stock i will purchase another kit if have some in stock, i really dont want to still burning and broken components (removing it from the PCB), i will purchase more if have in stock and will try to get better luck next time.
Im really not good removing components i already ****** up 1 transistor, 1 Zener, 1 LM3886
Old 26th February 2009, 05:30 AM   #239
CHecking one of the PCBs i noticed 36 volts between C14 Pins its OK? in the schematic i see that i need to have 24 instead 36, or im wrong?
Old 26th February 2009, 07:58 AM   #240
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Default Re: Re: C9 & C21 Caps comparison
C9 and its bypass(C21) are in the feedback loop so they're directly in the signal path. C13 is also directly in the signal path but it could be removed if you DC couple... and could be a film type too...
You'll find that the side walls of the case are more than enough.
With my Gainclone modules the side walls was cold, with MyRef they get warm (ca 42C/107.6F) in a room temperature of 20C/68F.
The Elnas are 5mm lead spacing and 12,5mm diameter vs 5mm ls and 10mm dia of the FMs
In the attached picture you could see how a 12,5mm cap fits.
Dario
ClaveFremen "Bailando Salsa en el Sietch"
The new "My Ref" Rev C threadHide this!Advertise here!
The "What slogan would you have if you were a high-end audio company?" Thread. Spasticteapot Everything Else 118 27th September 2011 03:31 AM
Original ECL86 "Baby Huey" thread jkeny Tubes / Valves 14 23rd November 2009 07:35 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
Copyright ©1999-2017 diyAudio
