The new "My Ref" Rev C thread
Old 10th November 2017, 01:53 PM   #1971
jls001 is offline jls001  India
Default MyRef Rev C Troubles
I've been using my MyRef Rev C (Linuxguru board + kit) for nearly a year now without trouble. The other day it went silent.
I opened it up and found that R11/1R had become open on both channels. I replaced them, powered it up on the bench, checked for offset voltage on both channels (around 7-8 mV) and connected the amp back in the chain since it was on without any obvious issues for more than one hour on the bench. On powering it up, I'm greeted by a loud continuous noise on both speakers.
Opened up once more and found the same resistors R11 had blown again. Same replaced and offsets are normal. Supplies to both opamp and 3886 are also normal.
I'm afraid to connect it back till I know what more to check.
Any advice, please?
Old 10th November 2017, 02:02 PM   #1972
linuxguru is offline linuxguru  India
Send a message via Yahoo to linuxguru
Any advice, please?
I'd suspect that the opamps in both channels blew, probably as a result of a mains spike or similar. You can replace the LM318 with a TL071 for a sanity check - if it works with modest offset with a TL071, then the LM318 is suspect (By any chance, is it an LF01 hybrid discrete opamp?)
It's also worth checking your source, especially the trafo and grounding.
Old 10th November 2017, 02:44 PM   #1973
Joseph K is offline Joseph K  Hungary
For me, the fact that offset is ok on the output after replacement says that th lm318 is ok..
What is not Ok is the source. It seems to create a common offset on the input! That is that burns the R11
Old 10th November 2017, 02:59 PM   #1974
I'm using TI's LM318, not the discrete LF01.
I have spare TL071. I'll try it. Thanks for the advice.
Old 10th November 2017, 03:44 PM   #1975
The same chain works fine with my other power amp. But in any case let me check the output of my buffer. Thanks for the pointer.
Old 17th November 2017, 03:00 AM   #1976
mamadudin is offline mamadudin  Indonesia
Any advice, please?
It happens for my amp too, twice but always only on L-channel.. there is no differences between L & R channel except CL-60. I installed CL-60 only on R channel while the L channel does not
The new "My Ref" Rev C threadHide this!Advertise here!
The "What slogan would you have if you were a high-end audio company?" Thread. Spasticteapot Everything Else 118 27th September 2011 03:31 AM
Original ECL86 "Baby Huey" thread jkeny Tubes / Valves 14 23rd November 2009 07:35 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
