The new "My Ref" Rev C thread
Old 1st October 2013, 07:28 PM   #1701
bcmbob is offline bcmbob  United States
I went through a similar struggle when transitioning from Siva's board to the FE - different PCB setup. Assuming the wire functions are correct, what about you developers using different size fastons for power inlets in future offerings? Pretty fail-safe with speaker pads.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 1st October 2013, 08:36 PM   #1702
piggybladder is offline piggybladder  Serbia
Originally Posted by troystg View Post
"..I may have interchanged PGND with AC1 or 2 in error and in haste.."
More likely an explanation as the boards are well proven and excellent.
But it still bites.. Sorry to hear.
Yeah think I'm gonna run with this as the most likely explanation for now Tbh I'm not too bothered about making mistakes as it's quite instructional so long as it don't cost me my health or my wallet too much, which it hasn't. I'm in it as much for the intellectual stimulus as much as for getting a decent sounding amp for a decent price!
Gonna concentrate now on getting my second board up and running properly with aforementioned changes to R1,R4,C13 and anything that springs to mind from various optimized BOMs around here. Per ardua ad astra as they say
Old 1st October 2013, 08:41 PM   #1703
FE = Fremen Edition, Bob?
Old 1st October 2013, 08:55 PM   #1704
Yes, You can read about it in the posts before and after THIS ONE.
Bob M.
Old 1st October 2013, 10:13 PM   #1705
Fantastic. That's a bookmark in my browser for sure. Always good to gain from another's struggles. The layout of your pics at post 155 in that thread is precisely what us newbs need to see. I was happy also to confirm from the phasing tutorial that my traffo is indeed in phase.
Old 1st October 2013, 10:31 PM   #1706
Bob M.
Old 2nd October 2013, 01:06 AM   #1707
Just so I'm absolutely clear if I join black and yellow on my traffo pictured it's in phase yes?
Old 2nd October 2013, 01:14 AM   #1708
It's not just the colors that matter. You need a meter or continuity tester to determine which wires to select. A Pair of wires that makes the meter beep/light up is considered in my words -a circuit. Once identified I usually mark both of those with a black magic marker, tape or colored heatshrink tubing. Then check the other two to confirm continuity in that second pair. The psudo-CT is made from combining one wire from each pair. I'd feel really shaky trying to do it with colors only.
Bob M.
Old 2nd October 2013, 01:24 AM   #1709
Well blow me. I've only ever worked with properly labelled traffos and always laboured under the assumption that the second of the first pair of secondaries always joins to the first of the second pair and was in phase. DIY mags do that for you. I really should go and build the Decibel Dungeon bulb tester.
Old 2nd October 2013, 01:32 AM   #1710
The bulb tester is essential (I have 3 styles), but I hope you are not confusing functions. The test I described can be done with that, but it's primary use is preventing damage at first power-up when the transformer is connected to an amp. A simple 1.5V flashlight battery and a bulb can be used as a continuity tester of you don't have a meter with that function.
Bob M.
The new "My Ref" Rev C threadHide this!Advertise here!
The "What slogan would you have if you were a high-end audio company?" Thread. Spasticteapot Everything Else 118 27th September 2011 03:31 AM
Original ECL86 "Baby Huey" thread jkeny Tubes / Valves 14 23rd November 2009 07:35 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
