Old 4th February 2009, 10:12 PM   #21
I just received my kit, and I have a couple questions regarding possible customization.
First, I intend to use this amp to power mids/highs of actively crossed speakers. Therefore, no need for bass below 100Hz or so. In fact, if it improves the handling of the upper freq's and allows me to safely use lower impedance midrange speakers, I would prefer to filter lows at the amp's input. Can I adjust the DC blocking filter C1/R1 to raise the cutoff without harming the rest of the amp? Could I use this filter to eliminate that portion of the active xover altogether? Is it 6dB/octave? In that case, I'd want a -3dB corner of about 150Hz.
Second, can the gain be adjusted to match the amp I'll be using for the bass speakers, or is the Rev C's gain fixed?
Peace,
Tom E
Old 4th February 2009, 10:46 PM   #22
vonfilm is offline vonfilm  United States
I will be following this thread closely when my kit arrives.
Old 5th February 2009, 04:26 AM   #23
Peter or Uriah:
There are two notes written on the PCB itself: one at R42 and one at R2 concerning the values of these resistors. I don't understand their significance, and I wonder how you arrived at the values you supplied in the kit. What is the effect of varying these component values? I am not second guessing you; I just would like to know how you chose these values.
Peace,
Tom E
Old 5th February 2009, 01:01 PM   #24
ClaveFremen's Avatar
Something to read:
R42:
http://www.diyaudio.com/forums/showt...502#post758502
R2:
http://www.diyaudio.com/forums/showt...710#post845710
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 5th February 2009, 01:37 PM   #25
schro20 is offline schro20  United States
schro20's Avatar
Originally posted by madisonears
at R2 concerning the values of these resistors. [...] I just would like to know how you chose these values.
The board is exactly the last board layout produced by TP including all the writing on the silk layer. The values of all components are exactly according to the last BOM produced by TP. This includes
that bypass caps were changed from 100nF to 220nF. These are C7/17/18/19/20/21. The silk say 100nF the contents of your parts bag have 220nF for these.
Peter
Old 5th February 2009, 03:04 PM   #26
Coreyk78's Avatar
I'm just thinking about things while I'm bored at work...
I got my kits yesterday but didn't have much time to really look things over yet, but I'm wondering if there are any capacitor locations where it would be worth it to use some boutique caps?
Reason I ask is I have some muse and silmic II caps along with a fair sized collection of Russian PIO caps, K42-Y, K40-Y, and FT-1 teflons. I will probably build it using the standard components first to use as a baseline, but I'm just wondering which caps would be good to bypass or replace if I do some tweaking in the future
Old 5th February 2009, 03:20 PM   #27
C9, if you you think Silmics or Muses are better than FCs in signal path.
I think so.
So I've already buyed 220uf 35V Silmic II and 220uF 50V Nichicon KZ for this position.
For C9 bypass I'll use a 0.01uF Vishay MKP1837.
Dario
Old 5th February 2009, 05:28 PM   #28
I got 220uf FM's in my kit, not FC's, for C1, C2, C9 and C14. Nice!
Please note that 100nf bypass C7, C17, C18, C19, C20 and C21 have all been changed to 220nf. The silk screen says 100nf, but that's where the AVX 220nf's go now. I would consider upgrading those, at least at C21.
I don't recognize coupling C13 brand. BOM says Kemet MKP, but label on cap says AV. That's probably where you'll get the best return with upgrade. There is plenty of room there and different hole spacing for a variety of cap types.
Peace,
Tom E
Old 5th February 2009, 06:13 PM   #29
For C13 I've selected Evox-Rifa PHE426, that according to Humblehomemadehifi 's caps test, should be pretty good; it will be bypassed by a Vishay MKP1837 as well.
Dario
Old 5th February 2009, 06:46 PM   #30
schro20's Avatar
Indeed. After originally thinking about getting FCs we realized that FM was better (and we got a better price; wonders happen).
Peter
The "What slogan would you have if you were a high-end audio company?" Thread. Spasticteapot Everything Else 118 27th September 2011 03:31 AM
Original ECL86 "Baby Huey" thread jkeny Tubes / Valves 14 23rd November 2009 07:35 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
Page generated in 0.11454 seconds (82.67% PHP - 17.33% MySQL) with 11 queries
