The new "My Ref" Rev C thread - Page 25 - diyAudio
Old 26th February 2009, 01:10 PM   #241
schro20 is offline schro20  United States
schro20's Avatar
Default Re: Re: Re: C9 & C21 Caps comparison
Originally posted by ClaveFremen
C9 and its bypass(C21) are in the feedback loop so they're directly in the signal path.
Doh. Of course.
peter
Old 26th February 2009, 01:19 PM   #242
marc brown's Avatar
In the attached picture you could see how a 12,5mm cap fits.
You could always install C9 on the bottom of the board if it gets too big.
Old 26th February 2009, 01:26 PM   #243
troystg is offline troystg  United States
troystg's Avatar
Originally posted by samsagaz
well, i will drop the boards to the trash, im really deseseperated, 4 Boards Build 1 works 3 NO
Btw, have any others in stock i will purchase another kit if have some in stock, i really dont want to still burning and broken components (removing it from the PCB), i will purchase more if have in stock and will try to get better luck next time.
Im really not good removing components i already ****** up 1 transistor, 1 Zener, 1 LM3886
Don't throw away the PCB's. They are still good even if the components are blown / burnt/ shot.
I promise to review the build today and look for issues.
At worst case you can ship the brds to me and I will reassemble them and ensure they are working before I ship back.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 26th February 2009, 01:52 PM   #244
schro20's Avatar
CHecking one of the PCBs i noticed 36 volts between C14 Pins its OK? in the schematic i see that i need to have 24 instead 36, or im wrong?
Dear Samsagaz,
I don't have my working board in front of me, otherwise we could compare (mine is in parts right now because I am building the case...)
You said you have one working board? I would recommend that you first compare this board with a non-working one. First do a visual compare of all the components. Then do test points like you seem to be doing and see what one board shows versus the other.
Just looking at the diagram you would expect to see less than 36 (obviously you expect about 24) when current is drawn. If no current is drawn there will be no voltage drop across R14.
What does your working board show?
Peter
Old 26th February 2009, 02:08 PM   #245
Reality first!
ClaveFremen's Avatar
Default Re: Re: Re: Re: C9 & C21 Caps comparison
Silmics are 25 mm tall, not so easy to mount on the bottom...
it's easier with C21, like I did for MKP1837.
Upgrading C21 to a MKS2 is cheap and a drop-in one, no space problems and has a big effect. (at least in my case)
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 26th February 2009, 02:45 PM   #246
Originally posted by schro20
Dear Samsagaz,
Peter
Well i already checked the boards and looks all OK. the one that works, start from 0V and start growing. When reach 24V the relay make contact!
the one that dont work start from 0V too but when reach the 24V dont make the Relay to Work!
Old 26th February 2009, 02:54 PM   #247
troystg's Avatar
Back up a little.
1. Picture of your pwr supply please. Trafo and wiring to the 3 inputs on the PCB.
2. Can you check the direction of each of the diodes on the boards? Make sure the bands are facing the correct direction.
3. Do you have ~37 volts on the LM3886 pins, ~ 12 volts on the 318 pins and 24 volts at the relay?
Troy
Old 26th February 2009, 03:27 PM   #248
Originally posted by troystg
Back up a little.
1 - Conections are OK, GND close to the BIG CAPS, AC1 and AC2 later
2 - Diodes checked everything OK.
3 - i have 70V between PIn 1 V+ and Pin 4 V- of LM3886 and in the LM318 after i turn on the amp, i get 20V that start droping.. after like 5 seconds i have 17v.
Old 26th February 2009, 03:34 PM   #249
troystg's Avatar
1. picture please.
3. 318 should have +/- 12 volts if I am not mistaken. If I recall correctly it is regulated via a 12 volt Zenner.
Troy
Old 26th February 2009, 03:37 PM   #250
schro20's Avatar
Correct. See http://www.diyaudio.com/forums/attac...amp=1234532041
peter
The "What slogan would you have if you were a high-end audio company?" Thread. Spasticteapot Everything Else 118 27th September 2011 03:31 AM
Original ECL86 "Baby Huey" thread jkeny Tubes / Valves 14 23rd November 2009 07:35 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
Copyright 1999-2017 diyAudio
