The new "My Ref" Rev C thread - Page 2 - diyAudio
Old 13th December 2008, 05:06 PM   #11
frog993 is offline frog993  Germany
Originally posted by AndrewT
There is yet another alternative.
Keep the parallel bass/mids and design a parallel chipamp to drive the combined 4ohm load. Each chipamp sees an effective 8ohm load and is designed as such. This is my least favoured solution.
Its possible to parallel the RefC ? If have ordered 2 complete monokits and 2 PCBs in the groupbuy. So i can build 4 monoamps.
I dont want design a new amp, i only want to know what is the best middleway of secondary rating for the RefC and my speakers.
To throw away one bassdriver is no solution for me. And yes all of the WS3BF are the same.
Udo
Old 13th December 2008, 05:30 PM   #12
I have no problem with my REV_C with 4 ohms speaker system, both a 4 ohms full range and a dual 6" tower of course at 4 ohms.
I am not sure did Andrew talking about most general chip amp, or exactly about the REV_C, since be honest, I have to say thanks since Andrew did tried to solve my questions in some threads, but he seems always considering the solutions at very general situations, so most of his advises never suit my case.
So frog, did you test and hear problem from REV_C match with your speakers? Or you "think" there might be problem base on papers?
Old 13th December 2008, 06:20 PM   #13
I only want to know wich transformer works at best with the RefC and 4ohm speakers. I have joined in by the actually groupbuy of the RefC and need a transformer for this amp.
I dont want to buy a transformer that not works with my amp/speaker combination or blow away the LM.
What transformer are you using ?
Greets Udo
Old 13th December 2008, 06:42 PM   #14
I am using two 225VA transfomer order from farnell:
http://hk.farnell.com/multicomp/ti-0...25v/dp/4334723
One for each channal.
Actually 1xxVA per channal already fine, but I want this encapsulated type, the choice from Farnell is either 80VA or 225VA, plus I want better channal seperation, so I forced to use 2 x 225VA, if you go for one transformer, a 300VA will be more then just enough for stereo.
I am not sure have you read all single post in the original REV_C thread, I did, and I did remeber Mauro did told, he already optimum his design for not really impedance sensitive such as at 4 ohms loading.
Old 17th December 2008, 02:26 PM   #15
widman is offline widman  United States
Default Potential Potentiometers
I'm planning to use a potentiometer at input for volume control. I'm considering the following options:
Precision
Alps
Any opinions on these or other suggestions?
pete
Old 17th December 2008, 06:36 PM   #16
Reality first!
ClaveFremen's Avatar
Default Re: Potential Potentiometers
Mauro suggests a 10KOhm potentiometer, parts you'd linked are 25KOhm...
I've read yesterday on the italian forum audiofaidate.it that Alps blue line of potentiometer are not in the same league of MyRef.
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 17th December 2008, 06:44 PM   #17
I can get NOS 10K Noble if anyone want, it cost USD25/pc, but shipping cost maybe a matter.......
Old 17th December 2008, 07:16 PM   #18
Default Re: Re: Potential Potentiometers
Thanks for the information. I was under the impression that a 25K was appropriate for the amp. The Precision pot also comes in 10K, so I may try that one.
Old 17th December 2008, 11:00 PM   #19
Reality first!
This one seems nice and with reasonable cost:
DACT Type 23 Stepped Attenuator Potentiometer 10K
Or if you really want the original:
Original DACT 10K
PS
The 'precision' potenziometer with 10% tolerance is no so precise, IMHO
Dario
Old 18th December 2008, 11:48 AM   #20
Thanks for the links. The "Type 23" is the same price as the Precision potentiometer. The only question will be how it fits in my chassis.
pete
The "What slogan would you have if you were a high-end audio company?" Thread. Spasticteapot Everything Else 118 27th September 2011 03:31 AM
Original ECL86 "Baby Huey" thread jkeny Tubes / Valves 14 23rd November 2009 07:35 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
Copyright 1999-2017 diyAudio
