| Chip Amps Amplifiers based on integrated circuits |
#1681 |
Apart from the heatsinks, there is little difference in cost between the F5 and the MyRef. In fact, the F5 has fewer components than the MyRef. Yes, it is probably more complex to setup. But after setup, it does not require any more tinkering. It can deliver up to 54W in class AB. Also, low voltage gain is a desirable property in a power amp in terms of noise.
This is no disrespect to the MyRef though. Mauro's design is unique and of course sounds wonderful in its own way. |
#1682 |
Passive Aggressive
25W
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
#1683 |
umm... no, the F5 does 25W class A and then upto 54W class AB. As far as I know, the MyRef does about 40W. Anyway, I don't mean to start a war of words. This amp has some strong following. The F5 has its own set of followers and a thread that is 10,000+ strong and still going. Just wanted to say that it is worth finding out for yourself what the difference is between this amp and the F5. PCBs and transistor kits are readily available.
#1684 | |
The F5 is a 25W into 8r0 ClassA amplifier. It is also a 50W into 4r0 amplifier, but only the first 12.5W is in ClassA at this reduced load resistance. The MyRef is 50W into 8r0 and also 50W into 4r0. But the PSU must be built/adjusted to suit the two different load resistances to get that maximum power capability for each.
regards Andrew T. Last edited by AndrewT; 31st January 2012 at 09:09 AM. |
#1685 |
With mention of the F5, I'm wondering about another possible "improvement" on the LM3886, forced Class A. I've seen Walt Jung do it with op-amps at the line level, but I don't recall such a mod on a power amp. It seems a 100mA current source or sink connected to the chip's output would make the "first watt" Class A, and not create too much extra heat.
#1686 |
Potentially the forced single ended ClassA operation of the output stage could/would make for a good ClassA amplifier of low output.
But one cannot release that potential because the front end circuit to which we have no access falls woefully short of the performance standards of what we would expect of a low power ClassA amplifier. The ClassA version would certainly not make a good headphone amplifier.
regards Andrew T. |
#1687 |
It sounded better than the class A I compared against. More detail, better image, similar depth, better bass control. Theoretically, the way it operates will deliver performance just as good as a class A.
Hear the real thing! |
#1688 | |
| The "What slogan would you have if you were a high-end audio company?" Thread. | Spasticteapot | Everything Else | 118 | 27th September 2011 03:31 AM |
| Original ECL86 "Baby Huey" thread | jkeny | Tubes / Valves | 14 | 23rd November 2009 07:35 PM |
| "compact loudspeaker factory visit from "magico mini" thread | Nanook | Multi-Way | 2 | 4th January 2008 07:30 AM |
| The "Really simple and cheap speaker designs for the newbie!" thread. | Spasticteapot | Multi-Way | 5 | 19th March 2006 04:16 AM |
| Page generated in 0.11944 seconds (79.46% PHP - 20.54% MySQL) with 11 queries |
