Old 16th December 2011, 10:51 PM   #1661
Reality first!
ClaveFremen's Avatar
Originally Posted by mx2 View Post
When I turned it on, I heard a pop and saw sparks. It seems like I blew DR1 and DR2. Any theories for what happened? Can it be saved?
Do you think the heatsink could have caused DR1 and DR2 to blow on the first channel?
Sorry for your problem...
I suggest you to post the question to this more specific thread:
MyRefC build guide
BTW
Is your LM3386 the TF insulated or the T uninsulated?
If it's the T version:
  • did you use the insulator and washer between the LM3886 and the heatsink?
  • Is your heatsink 'floating' or is it grounded?
Don't worry anyway, it can be saved but probably you'll have to replace the LM3886, LM318 and rectifiers.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition GB Second Run
Old 16th December 2011, 11:35 PM   #1662
mx2 is offline mx2  Canada
MyRefC build guide
BTW
Thanks for the reply.
Its the insulated version. The other channel just blew. DR3 and DR4 this time
It happened right when I plug the power cord in. (I didn't use a power switch.)
I will make a post in the other thread as you suggest.
Old 16th December 2011, 11:39 PM   #1663
Reality first!
You're welcome
It happened when I plug the power cord in. (I didn't use a power switch.)
Then the heatsink it's not part of the problem
Perfect, I'll try to help you there.
Dario
Old 17th December 2011, 08:57 AM   #1664
Mx2,
build up and use the bulb tester.
Old 23rd January 2012, 03:03 PM   #1665
PJN is offline PJN  United States
Default F5 vs RevC ?
Has anyone here compared the RevC to the Pass labs F5 ? If so I'd ike to hear your opinions. I already have two revC's, but am looking for another project to build and was wondering if the F5 would result in a performance upgrade.
Thanks,
PJN
Old 23rd January 2012, 04:34 PM   #1666
troystg is offline troystg  United States
troystg's Avatar
Originally Posted by AndrewT View Post
Mx2,
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 23rd January 2012, 05:01 PM   #1667
udailey is offline udailey  United States
Passive Aggressive
PJN,
I like the MyRefC a lot, but its not going to compete with the F5.
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 23rd January 2012, 05:05 PM   #1668
Thanks Uriah, that's what I was looking for.
Old 23rd January 2012, 07:47 PM   #1669
bcmbob is offline bcmbob  United States
OK Uriah - you knew it was comming Can you give a bit more info about the comparison between the MyRef-C and the F5?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 24th January 2012, 01:36 AM   #1670
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Thanks,
PJN
Which BOM are you using?
The simpler a design is, the more components are going to be critical on performance with the power supply considered as part of the circuit down to the transformer. I have no doubt that the F5 will need the exact components to get the exact performance.
Hear the real thing!
The "What slogan would you have if you were a high-end audio company?" Thread. Spasticteapot Everything Else 118 27th September 2011 03:31 AM
Original ECL86 "Baby Huey" thread jkeny Tubes / Valves 14 23rd November 2009 07:35 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
Copyright ©1999-2013 diyAudio
