Old 9th December 2008, 05:05 PM   #1
Default Best Tweak I have ever performed on Audio Sector GC3875
If your capacitors can is isolated from the inside (Blackgate Type N are like mine) then you can wrap wire on one then to the other then to your ground....
Extreme improvement in how smooth the sound is, mine also has a 1.2kohm instead of 600ohm Riken and removed input resistor but the huge affect came with this mod.
Old 9th December 2008, 05:52 PM   #2
You will not get any closer to tube quality smoothness with a GC.
Old 9th December 2008, 07:13 PM   #3
Shouldn't there be another 1000uF cap in that amp?
Old 9th December 2008, 07:41 PM   #4
Under the rectifier board
Old 10th December 2008, 12:28 AM   #5
danielwritesbac's Avatar
Default Re: Best Tweak I have ever performed on Audio Sector GC3875
Is the power amp or the preamp/source earth grounded?
Old 10th December 2008, 12:45 AM   #6
No, just neutral. I have found earth ground to be nothing but a pain in the butt in GC's.
Old 10th December 2008, 04:51 AM   #7
could you explain exactly what this mod does?
Old 10th December 2008, 08:30 AM   #8
Ted205 is offline Ted205  United Kingdom
Ted205's Avatar
so you've wrapped wire around the capacitors to ground ?
Old 10th December 2008, 04:18 PM   #9
Atilla is offline Atilla  Norway
Soldering Gun Fanatic
So how does grounding the casings of the caps do anything at all?
Old 10th December 2008, 04:25 PM   #10
Well these capacitors often carry a little bit of induced charge. This eliminates that first of all. Next it is affecting the electromagnetic field, causing a sort of shield if you will.
If it was on signal capacitors the removal of the charge could be good because I assume what it does is it steal a tiny bit of electron draw which would be the tops and bottoms of higher frequencies, creating a harsher sound. I based this idea on the concept of grounding speaker baskets which has that exact affect however the speaker baskets do not always charge and can take awhile to do so, making A-B comparison impossible, but this is just obvious.
There is no way to prove what it is doing unfortunately but the results are worth it, and there is no bad side affect at least with Blackgate type N capacitors because they have isolated cans. The voltage on the can may be high at times but the amperage is almost non-existent.
Try it Hell try it even without removing the plastic jacket, it might give similar results in the case of power supply caps. But I can tell you in a Audiosector amplifier with the 1000/100 STD/N cap combo the 100 N caps to the chip sound a lot better naked before this mod too.
Audio sector gainclone. dome406 Chip Amps 33 31st May 2010 02:12 AM
audio sector- lm4780 kit richyrich212t Chip Amps 1 25th August 2007 10:14 PM
FS: Audio Sector DAC $180 sts9fan Swap Meet 2 8th June 2007 01:46 AM
Finished Audio Sector NOS DAC* vdi_nenna Digital Source 4 4th February 2007 05:49 PM
Help with Audio Sector NOS DAC vdi_nenna Digital Source 14 14th January 2007 03:31 AM
Page generated in 0.09163 seconds (78.34% PHP - 21.66% MySQL) with 11 queries
