Intrest Check : Pretty Simple Digital Preamp / Volume Control
Old 14th December 2008, 09:51 PM   #61
rhysh is offline rhysh  United Kingdom
rhysh's Avatar
Send a message via MSN to rhysh
Here is the 'dirty' version of the schematic.
Note, it is correct, but hard to understand maybe.
http://www.cdupload.com/files/42436_...raft%20SCH.pdf
Sorry the values are not on the schematic, all the values are on my paper diagrams at the moment.
Rhys
Old 14th December 2008, 10:07 PM   #62
rhysh's Avatar
I forgot to mention, rerember to use capacitors on the input, and on the single ended outputs. High quality films a must.
Old 15th December 2008, 06:59 PM   #63
rhysh's Avatar
Hi Everyone,
To save me some trouble, could you please order your boards thru my online shop here. .
Also, i added a bit of info about the preamp here.
Cheers.
Old 16th December 2008, 08:27 PM   #64
rhysh's Avatar
Are people still intrested?
Old 16th December 2008, 08:46 PM   #65
Dr_EM is offline Dr_EM  United Kingdom
Dr_EM's Avatar
Still interested, might be a week or two buying, got a few things to sort out. Your online shop looks like it will charge postage even though I'm in the UK?
Old 16th December 2008, 08:47 PM   #66
rhysh's Avatar
If you are the bottom, you will see there is a option to remove postage if prior discussed, or if you are in the UK.
Rhys
Old 18th December 2008, 12:19 AM   #67
rhysh's Avatar
Put this on the backburner for a while. No money left.
Old 19th December 2008, 09:41 PM   #68
gfiandy is offline gfiandy  United Kingdom
gfiandy's Avatar
Rhys,
You design is not optimal in some ways. Would you like me to describe them or just shut up and go away :-)
Andy
Old 19th December 2008, 11:55 PM   #69
rhysh's Avatar
Originally posted by gfiandy
Rhys,
Andy
Hi andy. Feel free to describe my mistakes.
Old 20th December 2008, 07:14 PM   #70
gfiandy's Avatar
Hi Rhys,
The most significant problem is decoupling. You have no decoupling capacitors on the 5V rail at all. This will mean there is lots of noise on it.
There should be a bulk decoupller of 100uF at least. then 100nF caps shoudl be placed close to the micro controller and the 5V supply to the pre amp chip. I would also use an inductor to reduce noise from the Micro controller getting into the pre amp chip via the PSU.
I recomend re-reading the 7805 data sheet you should have some input and output decoupling on this part, however I can't remeber the optimal parts.
I'd recomend an input filter on the opamps to reject RF noise say 100pF to GND. However this is one of those value judgements as in a sirtuation where these is very little RF noise the system may sound better without them, however if there is noise about it will upset the input to the opamps.
I would recomend much more decoupling on the +/- 15V rails to ensure all th opamps and the output of the preamp as completely stable. 4.7uF to 10uF for each chip would be optimal with a seperate 100nF cap for each chip as well. However there is clearly some decoupling alread there and this will rpobably be ok.
I can't see where the +/- 15 comes onto the PCB it doesn't seem to have a connector, but I may have just missed it.
Andrew
Intrest Check : Pretty Simple Digital Preamp / Volume ControlHide this!Advertise here!
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 04:12 AM
Simple, SIMPLE Digital volume control -_nando-_ Digital Source 5 21st December 2006 02:20 PM
Intrest check - Kepco DC Power Supply - 48v 1500 watts owdi Swap Meet 3 5th March 2006 08:03 AM
