| Chip Amps Amplifiers based on integrated circuits |
Hi everyone,
I need a voltage buffer to match impedances in a summing buss that I am building. Can the LM3875 be configured to work as a voltage buffer with a gain of -1? My power supply is a bipolar 24V. I would be very grateful for a circuit. I'm unsure about what Rf/Ri ratio would be optimal for this. I need to buffer a 50k or 100k pot. The pot atteunates the output of a John Hardy 990 discrete opamp configured a a summing amplifier. The output of the 990 feeds the pot which in turn feeds a cinemag output transformer. I can't really use a regular buffer chip because the 990 has a 28dBu headroom which means the 990 could easily output 19V signals. Therefore I need a buffer that can handle input voltages of about 19V (or 28dBu of headroom). The output transformer is a Cinemag CMOB 1 with a 680 ohm input impedance and a 1:1 turns ratio. alternately do you folks out there have suggestions for another chip that would work better? Thanks in advance! Jason. |
#2 |
a discrete opamp follower by an IC buffer?
Use any of the discrete FET buffers that abound here. Select one that can run on >=+-30Vdc rails. Start with Pass.
regards Andrew T. |
#3 |
Why on earth would you want to use the LM3875?
Number 1 - it's not unity gain stable so it will make an excellent RF oscillator. Number 2 - there are far better OP-AMPS with far lower distortion you could use. |
#4 |
Yes, I think a discrete buffer is the right way to go. Could you guys please post links to threads that discuss discrete buffers? I couldn't find any. I'm basically a tube guy ; ) this is really my first solid state project and its for a friend!
#5 |
wrong post, please delete.
Any solution is a compromise. |
| LM3875 Voltage | Puffin | Chip Amps | 65 | 22nd March 2008 07:59 AM |
| Tube buffer PCB for LM3875 | neil_kaye | Chip Amps | 0 | 28th August 2006 03:20 PM |
| Looking for Tube buffer board for LM3875 | neil_kaye | Swap Meet | 0 | 28th August 2006 02:00 AM |
| Look for tube buffer for inverted LM3875 | Mrpong | Chip Amps | 7 | 26th July 2006 08:18 AM |
| Page generated in 0.08714 seconds (77.71% PHP - 22.29% MySQL) with 11 queries |
