| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Chip Amps Amplifiers based on integrated circuits |
Thread Tools |
#11 | |
#12 | |
#13 | |
There isn't a lot of difference. An LM4780 is two LM3886s in one chip. The maximum heat dissipation is lower, but the power consumption is very similar. |
#14 | ||
The advantages of separate rectifiers for positive and negative rails are less losses in the transformer, better power distribution across the secondary windings, better regulation and better suppression of noise (hum) during unbalanced load situations. Disadvantages are higher component count = higher price and double the voltage drop. And of course two separate bridges only make sense with double secondaries, not with center tapped transformers. Quote:
If you've always done it like that, then it's probably wrong. (Henry Ford) |
| Thread Tools | |
| gainclones single chip vs parallel config | ruijorgemoreno | Chip Amps | 28 | 26th June 2009 08:22 PM |
| two single secondaries, two rectifier boards lm4780 kit | gbolly | Chip Amps | 5 | 23rd August 2008 07:59 AM |
| Using 2 gainclones to create powered speakers. | haziz | Chip Amps | 5 | 25th April 2007 04:25 PM |
| Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? | zxx123 | Tubes / Valves | 4 | 21st February 2005 04:02 AM |
| Bridge Rectifier Replacements and Single-to-Quad Adapters?? | Sampsa | Parts | 0 | 15th June 2004 03:09 AM |
| Page generated in 0.07452393 seconds (72.72% PHP - 27.28% MySQL) with 10 queries |
