| Chip Amps Amplifiers based on integrated circuits |
#11 |
About you commenting on the tweets sensitivity. If the set up is using passive xovers then the amp will drive to the same level but dissapate the extra power thru the L pad or attenuative resistor, so you would need the same power. However if this is an active set up and you reduce the gain to the amp thats a different matter entirely.
#12 | |
audioPT If you don't mind can you share with us the schematics of your LM12CLK ? I have a few of those IC maybe I can use your schematic to build an amp. Thanks |
#14 |
audioPT
Thank you very much for the info got it, will be building that one soon. How does it sound? Thanks again. |
| PC sound card sound chips | kaluchka | Chip Amps | 6 | 20th June 2011 03:48 PM |
| Eighteen Sound (18 Sound) NSD 1095N Compression Drivers and XT1086 Horns | opc | Swap Meet | 6 | 1st May 2009 03:48 AM |
| Chips for Chumps aka "Intelligent Chips" | jackinnj | Solid State | 0 | 15th April 2005 12:37 AM |
