| Chip Amps Amplifiers based on integrated circuits |
I need a good opinion on how little (small) gain I can use with lm3886 and still be able to use its full power?
I'd like to do an experiment that involves much more input, much less gain. If I use the minimum gain of 10, would I be overdriving the input before the LM3886 is producing its 68 watts? If so, how much gain do I need in order to stay out of trouble? Thanks! |
#2 |
It says right in the datasheet the IC needs at least a gain of 10 to be stable. I don't think you will be overdriving the input at full power; it can take a 60V differential input signal when used with an 80V supply.
"If you don't like funerals don't kick sand in ninja's face." |
#3 |
With appropriate feedback circuit, you can make it work even with gain = 1 (in inverted mode). I can give you exact schematic if you'll tell me what gain you need.
Nick |
#4 | |
Hi there, do publish the feedback circuit for a gain=1 amplifier. That's interesting. Many thanks.
regards, Will |
#5 |
I'd like to see it at 2x, or 4x, or 8x--even multiples if you don't mind.
#6 |
This one for example has a gain = 3.
-------------------------------------------------- Sorry, I was simulating and did not notice your new posts. I'll post tommorow what you need. |
#7 |
Its a good illustration.
My question was really about a non-inverting LM3886. How little gain can I use there and still have all of its power available, but without overdriving the LM3886 input? In a related question, can 100R or 1k be used for input load and and NFB? (pre=headphone amp) |
#8 |
Common Mode Input Voltage ( V+ or V- )and | V+ | + | V- | <= 80V. So I think it could work for a noninverting LM3886 too, but distortion will be much higher than in inverting.
#9 | |
#10 | |
Inverting is fine then. I take it that we can invert both the amp and the pre so that it will come out straight?
| Flatter than flat. PHL 10" and Beyma 1,4" | Lindell | Multi-Way | 24 | 18th May 2009 09:51 PM |
| Why "Flat" is Inaccurate | DDF | Multi-Way | 86 | 26th July 2007 01:08 AM |
| How Flat is "Flat"? (XT18WO + 27TBFC-G = MTM) | zenon | Multi-Way | 3 | 21st January 2007 04:15 PM |
| Project "The Drummer"-Flat DIY sub driver | ZuMbAiU | Subwoofers | 0 | 28th January 2006 11:40 AM |
| opinion about this "tb" tweeter | hobby1 | Multi-Way | 4 | 2nd June 2005 03:29 PM |
| Page generated in 0.11444 seconds (76.83% PHP - 23.17% MySQL) with 11 queries |
