| Chip Amps Amplifiers based on integrated circuits |
HI! I'm a rookie on electronics, but I love audio and decided to build a simple amplifyer and this one lokes simple and cheap...
I bought all the stuff and mount it on a protoboard.. How can I test the TDA? the circuit doesn't makes any sound... Who can help me??? How to test the circuit? Thanks
#2 |
Believe it or not, but a schematic of how you have connected the different parts together would be a bit helpful....
#3 |
Hi...
Sorry, but school has been ocuping all my time... An image goes attatched on this reply... And sorry about my inactivity.. Thanks |
#4 | ||
What means do you have to test? Multimeter? Oscilloscope? Frequency generator or CD with test signals? PC soundcard? Power resistors? Set of cheap test speakers? The normal way is to either connect a cheap speaker or some power resistors to the output. Then feed a test signal to the input and measure along the signal path until where the signal goes. If you use a multimeter, try a test signal below 150 Hz. That is, where multimeters work best. On the other hand don't use too low frequency with too small test speakers. With a 3,5 mm connector as in the schematic, it is not uncommon to have a bad connection already there. If you post photos, somebody might be able to spot obvious faults.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#5 |
Hey..
I build the circuit on a breadboad and I already check it 3 times and I had already also re-build it... to test, I only have a multimeter and it is one of the cheapest ones... My power supply were taken from a pc an it is working well... I'm using 12v output. I use a speaker with 10W, and it is also working well... but would ir be necessary to use 4 speakers??? Abou the jack, it is ok. i connect thee speaker and it sound almost like a headphone, but it makes a sound... On friday I'll check that voltages. Thanks |
| TDA7386 Car Amp | Redshift187 | Chip Amps | 21 | 26th May 2009 12:13 AM |
| PCB for TDA7386 Amplifier | enecumene | Chip Amps | 1 | 16th May 2009 02:19 PM |
| TDA7386 Problem please help | Brownstocker | Chip Amps | 5 | 28th January 2008 10:02 PM |
| Tda7386 | koloko | Chip Amps | 1 | 18th June 2007 08:25 AM |
| Problem with TDA7386 | SideWinder | Chip Amps | 0 | 24th May 2004 10:13 AM |
| Page generated in 0.09214 seconds (72.04% PHP - 27.96% MySQL) with 11 queries |
