Intrest Check: 120w @ 8ohm Tube Buffered LM3875 Amplifier
Old 17th December 2008, 10:44 PM   #91
kierownik is offline kierownik  United States
kierownik's Avatar
will the boards you ordered sport gold plating?
Old 17th December 2008, 10:46 PM   #92
rhysh is offline rhysh  United Kingdom
rhysh's Avatar
Send a message via MSN to rhysh
It would cost another 4 dollars per board, its not worth it for this kind of amplifier.
Old 17th December 2008, 10:48 PM   #93
kierownik's Avatar
i think it's a really nice touch, plus solder flows great on it
Old 17th December 2008, 10:53 PM   #94
kierownik's Avatar
i could still survive with 4 bucks less, although I might be wrong the economy is pretty bad
Old 17th December 2008, 10:57 PM   #95
rhysh's Avatar
I agree it would be nice, but it is OTT for a gainclone, this was intended to be a lost cost amplfier as you can see by the BOM, to say that everything is onboard.
Old 18th December 2008, 02:09 PM   #96
Brewboy is offline Brewboy  United States
Is the BOM still good for this build? Should I start to acquire the parts or should I let the " tweeking" happen first?
Where should I look for genuine parts? I don't want to get stuck with phony crap.
Old 18th December 2008, 03:03 PM   #97
rhysh's Avatar
You should be fine with that BOM. The only section that may need altering is the resistor for the 555 timer.
The bom includes digikey part numbers, i would use digikey.
Old 19th December 2008, 03:52 AM   #98
Hi Rhys
On the BOM you left out recommendations for the transformers. I would be more than happy to learn of any sources to acquire these components. It appears that purchasing these from Digikey would cost about $200, but then again I'm not totally sure what I'm looking at. Apex jr. is very confusing but has very low prices. Any other sources that I should explore?
Old 19th December 2008, 11:47 AM   #99
billyk is offline billyk  United States
billyk's Avatar
Check out Antek. Good toroids and reasonable pricing. For example AN-3220 is 2x20 300VA, ideal for the chip PS is priced at $36.00
Old 19th December 2008, 11:44 PM   #100
Thanks Billyk,
So if I use Antec part #s I would need
1 ea AN3220 $36
1 ea AN0112 $10
1 ea AN0120 $10
Is that correct ?
Intrest Check: 120w @ 8ohm Tube Buffered LM3875 AmplifierHide this!Advertise here!
Intrest Check : Pretty Simple Digital Preamp / Volume Control rhysh Chip Amps 69 20th December 2008 06:14 PM
Intrest check - Kepco DC Power Supply - 48v 1500 watts owdi Swap Meet 3 5th March 2006 07:03 AM
Sanity check - designing my speaker to be 8ohm amplifier friendly. owdi Multi-Way 4 1st November 2005 10:08 PM
