Old 30th November 2008, 08:04 PM   #11
danielwritesbac's Avatar
Originally posted by ide2003
hi there danielwritesbac, appreciated your tips.
will check mine, schem. attached, I use 50k pot, C1=2.2u, R1=1k, R2=20k in that order.. is this the culprit of 'big' dc-offset?
thanks
TPS
Yes it is.
You can change R2 to 10k and then you can measure lower dc offset as the result. This may change the capacitor size needed at C1.
Tip:
Imagine. . . the pot needs protected from DC entrance, which can come from a buffer, preamp, or source.
Imagine. . . a future buffer/pre project. Have a look at some examples and see how they will connect to your amplifier.
EDIT: I will conduct an experiment today with both feedback and input load as 10k. Also, I'll set "nfb seeks ground" the same value as "input series" resistor. This is the way of a balanced amplifier; however, there's an additional step that I either don't know or can't remember.
Old 1st December 2008, 09:17 AM   #12
WOW!!!
The analog meter didn't budge on its most sensitive setting. Normally, it'll show about 45mv on my amps.
The digital meter on its "200m" scale read 00.1. My fingers could get it to read 08.2, so, apparently my body makes more dc offset than this amplifier. It could be paralleled without the typical heat penalty.
I had to use a smaller-than-usual gain setting because there was too much.
The bass is nice!
Old 2nd December 2008, 04:39 PM   #13
ide2003 is offline ide2003  Indonesia
WOW!!!
The bass is nice!
men!. you're fast!..thanks, so many to try..so little time..
TPS
don't quite understand this, danielwritesbac, a schematic is great thanks b4
Old 2nd December 2008, 05:01 PM   #14
and you know what
means.
regards Andrew T.
Old 2nd December 2008, 05:33 PM   #15
Originally posted by AndrewT
and you know what means.
nice that you come-by AndrewT, you know, this EE talks that keeping me going gaa-gaa all the time..I can read the schem, can solder, do a nice mech job..but gave up on these..
TPS
Old 2nd December 2008, 05:53 PM   #16
we've all given up trying to persuade Daniel to use the conventional language that we can all understand.
regards Andrew T.
Old 2nd December 2008, 08:33 PM   #17
I forgot how to call "sides" of a voltage divider. Low leg? High leg?
Sorry about that.
Since this isn't using a DC null circuit, and so its off topic, I moved the discussion of my experiment (soon to list a schematic) over to: 10k nfb and 10k input impedance. Anyone tried it?
Old 2nd December 2008, 08:54 PM   #18
ratza is offline ratza  Romania
ratza's Avatar
Sorry about that.
How about in and out?
Any solution is a compromise.
Null Test tbrooke Pass Labs 6 12th May 2009 04:51 PM
Fortuitous distortion null in simple FET circuit scott wurcer Solid State 12 18th November 2008 12:27 PM
take a look at my fr plots and tell me what you think about that null pjpoes Multi-Way 14 19th July 2008 03:44 AM
How to interpret reverse null? Jay_WJ Multi-Way 7 11th April 2007 01:36 AM
Page generated in 0.10420 seconds (78.08% PHP - 21.92% MySQL) with 11 queries
