| Chip Amps Amplifiers based on integrated circuits |
I'm mentally designing the housing for my future gainclone and was wondering if it would be an adequate heat sink if the chips were attached to a quarter inch thick, 5" x 7" aluminum plate (one of the outer walls)?
#2 |
one 5"x7" per 3886 should be ok, considering at least 10 mm thickness of aluminium sheet. but you have to keep it in a good air circulation zone
. . .. ... ..... ........ ............. ..................... .................................. My Best LM3886 PCB layout |
#3 |
So that's two sheets. I can do that (I live next door to an ex GM prototype machinist). I was thinking of sort of a "tower" arrangement and I can mount one chip on each side wall. The power source will be elsewhere and all the jacks will be on the back with some interesting wood on the top and front.
I'd like to place the power unit in a black box out of sight. Would it still be sucking power if there is no draw from the amp? (carbon footprint and all...) I could put a switch on the back of the amp. I'd like to not have to crawl under the media center to turn it off. Basically I want it to be a high tech wall wart....
#5 |
The heatsink could be improved if the whole box were made from aluminium. But all the joints would need to be thermally coupled to minimise resistance to heat flow.
Keep in mind that the inner surface of the box will be warmer than the outer surface. You must provide ventilation to prevent overheating of the internal components.
regards Andrew T. |
#6 | |
I am in the process of designing a couple aluminium enclosures for my dual mono Chipamp. Ventilation is something I have been thinking about over the last couple of days. I obviously what there to be enough ventilation, but because of the design I don't want to drill to many holes. What would you recommend? A bit a daft question...so please don't shoot me down ![]() Regards Richard |
#7 |
Zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
#8 | |
#9 |
I wondered where my hair had gone
| Which heatsink? | wxn | Chip Amps | 2 | 10th April 2005 01:43 PM |
| One heatsink for each mos ? | pa | Pass Labs | 3 | 1st April 2002 10:29 PM |
| Page generated in 0.09710 seconds (72.82% PHP - 27.18% MySQL) with 11 queries |
