| Chip Amps Amplifiers based on integrated circuits |
I have fitted heat sinks to the 338's, but find that they remain virtually stone cold in operation. The chip heat sink gets mildly warm, but not a warm as before adding the regulation.
Have any others found this? I use very efficient speakers and so the amp is under no stress. |
#2 |
it depends on the voltage you are putting into them, the voltage out, and the current drawn by the amp
#3 | |
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#4 |
typical music levels are average power out ~=peak power out/100 (-20dB). if your 50W amp is peaking at 20W then the average output could be as low as 200mW. This is little more than running at quiescent current draw. Similarly the regulator is only supplying that 200mW + quiescent current draw and that times the volts drop across the regulator accounts for the tiny temperature rise in the sink. Try measuring the volts drop across the regulator, when no music is playing and when the music is as loud as you would normally play it.
regards Andrew T. |
#5 | |||
![]() Quote:
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#6 | |
200mW into 87dB/W/m speakers gives an averge level of ~75dB @ the listening position for a two channel system @ 2.4m listening distance. The peak level can be about 95dB and still have 30 to 40W (another ~5dB) to spare if you want to turn it up a bit more. Alternatively if ~75dB is too loud, then turn it down a bit. Either way it explains why the regulator and the chipamp are cooler than might be expected, if one has not thought about average listening levels.
regards Andrew T. |
#7 |
Nuuk and AndrewT. Thanks for your responses. I suspected that the current draw was actually very little. I came across a project that showed how to build a very simple peak level meter. I set the resistors for 1Watt. It was surprising how much (deafening)volume there was before the LED started to register.
| LM338 regulated snubberized PSU for audio amplifiers | carlosfm | Chip Amps | 511 | 25th September 2008 05:04 AM |
| PCB: LM338 Regulated Snubberized PSU | yusuf | Power Supplies | 7 | 27th March 2007 01:45 PM |
| Where to get the lm338 reg. in Europe (for Gainclone regulated PS)? | swak | Chip Amps | 3 | 15th July 2004 08:29 AM |
| Page generated in 0.09159 seconds (81.67% PHP - 18.33% MySQL) with 10 queries |
