| Chip Amps Amplifiers based on integrated circuits |
hello all:
what would be the expected output power in rms of a gainclone amp? i think it depends on the power supply rails but are not shure...any help? wicho |
#2 |
Might I suggest reading the datasheet?
A typical LM3886 implementation running from 35V rails is good for about 56W into 8 ohms. |
#3 |
Play with the Overture Design Guide from National Semiconductor. The gain depends on external component selection. The output power depends on input x gain, in addition to power supply voltage and the particular chip you are using. In other words, there is no simple answer.
| Any opinions on unity gain power amp? | wdyn1 | Chip Amps | 2 | 14th December 2008 03:43 PM |
| Altering Power amp gain | AndrewT | Solid State | 1 | 20th September 2006 02:55 PM |
| Audio Note Low Gain Quest Power Amplifier | kmtang | Tubes / Valves | 0 | 18th September 2006 11:55 PM |
| Lowering gain of power amplifier, good idea? | squadra | Solid State | 10 | 5th May 2004 03:43 PM |
| Inverted gain clone power amp only? | tubenut | Chip Amps | 1 | 26th March 2004 08:28 AM |
| Page generated in 0.06737 seconds (72.78% PHP - 27.22% MySQL) with 10 queries |
