Gainclone hum and digital multimeters.
Old 3rd April 2003, 06:47 PM   #1
Shoog is offline Shoog
Shoog's Avatar
Default Gainclone hum and digital multimeters.
I have just got one channel of my gainclone working. I have built it as a single supply so it has input and output blocking caps. I have a loud hum problem. I have tried single star grounding and I have tried double star grounding. In the double configeration I have all the grounds attached to one point, excepting the input grounds and the feedback loop ground.
Here is the strange thing, I attached my digital multimeter on continuity test between the output side of the output blocking cap and ground and the hum goes away. Is this a pointer to the source of the problem and if so what is it.
Shoog
Old 3rd April 2003, 06:49 PM   #2
Bricolo is offline Bricolo  France
Bricolo's Avatar
can you post your amp's shematic?
I don't exactly see how you builded it, and why you use an output cap
Old 3rd April 2003, 06:55 PM   #3
Shoog's Avatar
Default It is the standard single supply circuit.
It is the standard single power supply circuit given on the LM1875 data sheet.
Shoog
Old 3rd April 2003, 07:02 PM   #4
Bricolo's Avatar
maybe you were simply doing a short circuit with your multimeter
that's why you had no more hum
Old 3rd April 2003, 07:06 PM   #5
Shoog's Avatar
Default The signal was still there
The signal was still there so I dont think a short circuit would explain it.
Shoog
Old 3rd April 2003, 07:19 PM   #6
tiroth is offline tiroth  United States
Hmm...what happens if you tie the output side of the output capacitor to ground via ~100k-1M resistor? This shouldn't make a difference, but maybe a DC ground point at the amplifier side is helping for some reason.
Old 3rd April 2003, 08:53 PM   #7
nania is offline nania
Send a message via AIM to nania
Shoog
Is the continuity test on your meter also a diode test? Try reversing the leads and do the test the test again. If you return a hum, you defintely have a ground loop problem.
Gainclone hum and digital multimeters.Hide this!Advertise here!
digital crossover w/digital output? ezkcdude Digital Line Level 44 Yesterday 10:10 PM
Progress report - digital crossover as a DAC - digital all the way to the amps Ken L Multi-Way 0 26th November 2006 11:42 PM
Get digital signal from an old CD-Rom without digital output genome Digital Source 5 3rd February 2004 11:54 PM
