| Chip Amps Amplifiers based on integrated circuits |
#71 | ||
That's much easier to understand than "No" or "Where's the apology" or "ridiculous proposition". As per my earlier quote from the sound.westhost.com site: Quote:
Keep in mind when using 1 bridge per winding, there are double the number of diodes (twice the voltage drop) in the rail to rail path, which may eliminate any gains in efficiency over using a single bridge in the "economy circuit" layout. In my case I am building this PS circuit to power a bridged amp, and I was trying to understand what benefit there was to using 2 rectifiers, rather than one. In my case it is better to use just one. |
#72 |
I was just browsing around, and I noticed that the OP was having trouble with heat. My biggest suggestion would be to use very good thermal grease. It's not that expensive, but it will do a much better job getting the heat from the IC to the Heatsink. It doesn't change the heat dispensation requirement for the heatsink, but rather lets the heatsink do its job.
This stuff is basically the best. I mainly use it for computers, where thermal grease is VERY important, but it will do a fine job for IC->Heatsink connections. Arctic Silver 5 -West |
#73 |
Thanks for the link, but I am having trouble understanding how this applies for bi-polar supplies. Using the single bridge config (aka dual full-wave). One winding is supplying positive cycle, while the other winding is simultaneously supplying the negative cycle. The direction switches for each half cycle, but current flows through each winding for the entire cycle.
#74 | |
The whole winding flows in one direction and passes current through two of the diodes to the capacitor pair. If the +ve and -ve capacitors (plus the load currents if any) pass identical currents then, the centre tap passes exactly zero current. During the other halfwave, the whole winding flows in the opposite direction and the other two diodes steer the current through the capacitor pair in the same direction. The centre tap allows the loads to draw differing currents from the +ve and -ve halves of the capacitor pair. The centre tap passes the DIFFERENCE in output currents from the PSU. If there is ONE load from most +ve to most -ve then the +ve & -ve currents MUST be IDENTICAL. With this single load situation the centre tap is not required and can be left open circuit.
regards Andrew T. Last edited by AndrewT; 3rd November 2009 at 12:18 AM. |
#75 | |
#76 |
I think a single bridge rectifier will also do, but guess the only reason dual bridges are used is to reduce the ammount of current through each bridge rectifier ...thus getting away with a smaller i.e. cheaper rectifier.
I myself use a dual bridge rectifier..but haven't done any R&D into finding if the dual bridge makes any difference. |
#77 | |
#78 |
In a centre-tapped transformer current will only flow in one half of the winding during one half-cycle. If you use a dual secondary tranformer with full-wave rectification, i. e. one rectifier bridge per secondary, current will flow in each secondary during both half-cycles. That leads to a higher efficiency for the dual secondary version.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#79 |
Pacific,
I think you are not helping us understand by omitting to clarify which output currents you are referring to. Try again.
regards Andrew T. |
#80 |
I refer to the current that flows from the transfromer secondaries through rectifiers and amplifier to the speaker. I skip the quiescent currents, bias currents, etc.
A single amplifier channel will only draw current from one rail at a time. We can therefore limit us to the components that are active to supply one rail. If we look e. g. only at the positive rail, the centre-tapped transformer with two diodes forms, what my dictionary translates as midpoint connection. ![]() When the amplifier draws current, during the positive half-wave D1 conducts and current flows only in the upper half of the winding. During the negative half-wave D2 conducts and current flows only in the lower half of the winding. A single secondary with four diodes or a Graetz bridge translates to bridge rectification. ![]() When the amplifier draws current, during the positive half-wave D1 and D4 conduct. During the negative half-wave D2 and D3 conduct. In both cases current flows through the upper winding. Among other effects the difference in the resulting wave-form through the windings leads to a difference in the effective current that loads the primaries. An old textbook of mine contains a table that states the relations between transformer power Pt and DC power Pdc as follows. Midpoint connection: Pt / Pdc = 1,5 Bridge rectification: Pt / Pdc = 1,23 In other words for 100 W power consumption you need a 123 VA dual secondaries transformer with two rectifier bridges or a 150 VA dual secondaries or centre-tapped transformer with a single rectifier bridge. 100 W power consumption won't give more than 60..70 W of continuous amplifier output power from a class AB amplifier. A dual secondaries transformer with two bridges must be rated twice as big as the desired output power, while the centre-tapped or dual secondaries transformer with a single bridge requires a rating 2,5 times as big as the desired output power. If you want continuous maximum output power, that is.
| Dual supply for LM1875 split supply | dovganj | Power Supplies | 30 | 6th November 2009 04:19 AM |
| LM1875 power supply question (easy) | madisonears | Chip Amps | 12 | 24th February 2008 11:41 AM |
| Lm1875. Power Supply Capacitors | alcuemar | Chip Amps | 12 | 12th June 2006 04:11 PM |
| Power supply for 5 LM1875's | mangrovejack | Chip Amps | 10 | 24th April 2005 08:59 AM |
| Page generated in 0.13169 seconds (88.25% PHP - 11.75% MySQL) with 11 queries |
