Old 23rd October 2008, 11:08 AM   #1
gainphile's Avatar
Default Gainclone and B1 pre-amp
Seems like Nelson's preamp follows the minimalist philosophy.
Do you think it is a good idea to use this with GC ?
http://gainphile.blogspot.com
Old 23rd October 2008, 11:14 AM   #2
Default Re: Gainclone and B1 pre-amp
no.
Use the pre-amp/buffer to condition the signal coming from the source or from the attenuator.
Once you have a low source impedance, the GC (as you call it) or any power amp will be able to perform well.
The purpose of the pre-amp/buffer is to make the signal better.
It is not intended to make the power amp better.
regards Andrew T.
Old 25th October 2008, 03:48 PM   #3
juma is offline juma  Serbia
juma's Avatar
Hi gainphile !
B1 is very easy to build and it's surely worth a try. It is common knowledge that GC (LM3875, LM3886) will benefit sonically from good buffer on its' input.
Old 25th October 2008, 03:53 PM   #4
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Re: Re: Gainclone and B1 pre-amp
no, that it's not correct either. The GC (as you call it) does not need buffer on it's input. It's the inferior source, or passive attenuator, that needs it.
But certainly, B1 should work well with chip amp.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 25th October 2008, 08:37 PM   #5
juma's Avatar
Default Re: Re: Re: Gainclone and B1 pre-amp
Originally posted by Peter Daniel
... passive attenuator that needs it. ...
Yes, that's it, I tend to put the volume pot on GC's input
Old 26th October 2008, 10:06 AM   #6
That's the wrong place.
A source buffer should be located inside the source casing, i.e. inside the CD player, tuner, sound card etc.
An attenuator buffer should be located at the attenuator.
The buffer gives the ability to drive all that comes after it, including the cables and other parasitics.
regards Andrew T.
Freebird + Gainclone = "integrated" gainclone? bikehorn Chip Amps 9 5th January 2006 03:07 PM
JLH v Gainclone? Jezz-the-Fezz Solid State 5 12th December 2005 12:08 PM
Big gainclone steven344 Chip Amps 10 23rd November 2005 07:58 PM
Page generated in 0.08456 seconds (75.25% PHP - 24.75% MySQL) with 10 queries
