Old 6th February 2006, 02:21 PM   #211
Default batt psu for my phono stage
Hi, i was wondering if anyone can help me. I want to build an 18v batt psu for my graham slee phonostage but don't know where to start. After reading a few posts i'm thinking 2 x 12v SLAs with a voltage regulator and some smoothing caps. Put then i'm stuck, what order what values, what else? all help would be greatly appreciated.
Cheers
carlos671
Old 6th February 2006, 02:33 PM   #212
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
First question is does the phono stage use a single rail supply?
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 6th February 2006, 02:41 PM   #213
Default closer inspection
on looking at my wall wart i actually need a 24v power supply. where would i find out about that nuuk? the internet is a minefield
Old 6th February 2006, 05:24 PM   #214
Nuuk's Avatar
Well we need to know a bit more! The wallwart supplies 24 volts but is that what is used? Or is the voltage regulated down to say 18 volts? Do you have any documentation?
Old 7th February 2006, 08:58 PM   #215
i measured the psu with my multimeter and it was kickin out 31.5 volts. Do u know a good place to learn about electronics? what is the diff between dual and single rail? When i do searches i jus get loadsa computer stuff.
Cheers
Old 7th February 2006, 09:08 PM   #216
Electrons are yellow and more is better!
peranders's Avatar
Single rail = two wires from the PS, + and - but this requires a big capacitors in series with the speaker, not so good.
Duoble rial = three wires from the PS, +, 0 and - The normal thing.
I really recommend that you take a good look in the datasheet for the LM3886 and also check the application note AN-1192 because there you have all basic info about "Gainclones".
/Per-Anders (my first name) or P-A as my friends call me
Old 7th February 2006, 09:21 PM   #217
Nuuk's Avatar
Learning about all this is really a question of time and research. I try to make things simple to understand on Decibel Dungeon!
You could also try Googling for 'electonics theory' and if you add 'beginners' you should find plenty to get you going.
Old 8th February 2006, 08:23 AM   #218
i emailed graham slee about the psu. Yes it is a single rail design. What is the nxt step regarding the psu?
Old 8th February 2006, 09:02 AM   #219
Nuuk's Avatar
Being sure of the correct voltage!
Old 8th February 2006, 12:43 PM   #220
measuring with my multimeter i got 31.5 volts
Battery powered amp Shpoop Chip Amps 8 26th January 2007 04:41 PM
anyone using a battery powered pre? whatsnext Solid State 15 30th October 2006 12:26 PM
Battery powered PC ? percy Everything Else 15 7th March 2006 08:24 PM
battery powered gc in a tin digi01 Chip Amps 11 25th December 2004 05:11 AM
DC-33 DC Battery Powered Amp?? moe29 Pass Labs 2 26th April 2004 07:41 PM
Page generated in 0.26846 seconds (38.24% PHP - 61.76% MySQL) with 11 queries
