| Chip Amps Amplifiers based on integrated circuits |
#181 |
hmm how small is small? and what are you running?
#182 | |
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#183 |
i would say it would work for somthing low powered sure.
like a preamp. but if its for say a amp you would have to string alllot together for it to work and it will cost you as much as a single sealed 12v cell i say try it thay may run hot |
#184 |
Greetings,
I recently built a buffered "passive preamp" that is powered by SLA batteries. The sonic results are stunning. I used Shallco stepped attenuators with Resista resistors and OPA627 opamps as buffers. The batteries are rated at 7AH. <center><img src="http://207.115.74.87/vcm/WH/images/DCP_2316.JPG"></center> |
#185 |
nice work
#186 | |
What did you use for charger? I'm thinking about similar preamp.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#187 | |
Is that two stepped attenuators that you have used instead of one stereo? And before anyone asks, where did you get those knobs?
#188 | |||
<center><img src="http://207.115.74.87/vcm/WH/images/DCP_2305.JPG"></center>
#189 | |||
I like the feel of Bloore Edwards switches that I use now, but only after replacing the springs with something 'lighter'. Quote:
#190 | |
<center> <img src="http://www.kilointernational.com/new/Knobs/ML_Series/mlknobs.jpg"> </center> The two rings are like rubber O-rings. Come in diameters from .5 to .95 inches, for .125 inch, .25 inch and 6mm shafts and available in black and clear with gloss or matte options. se |
| Battery powered amp | Shpoop | Chip Amps | 8 | 26th January 2007 04:41 PM |
| anyone using a battery powered pre? | whatsnext | Solid State | 15 | 30th October 2006 12:26 PM |
| Battery powered PC ? | percy | Everything Else | 15 | 7th March 2006 08:24 PM |
| battery powered gc in a tin | digi01 | Chip Amps | 11 | 25th December 2004 05:11 AM |
| DC-33 DC Battery Powered Amp?? | moe29 | Pass Labs | 2 | 26th April 2004 07:41 PM |
| Page generated in 0.14688 seconds (79.38% PHP - 20.62% MySQL) with 11 queries |
