Old 9th October 2008, 10:34 AM   #1
ygg-it is offline ygg-it  Italy
Default In op-amp do not_symmetrical power supply cause distortion?
In an Opamp if I have + 15v in one rail and -14v in the other, this may cause distortion (even at low level) ?
(I'm using lm 317 and 337)
My projects (G.G. Italy)
Old 9th October 2008, 10:54 AM   #2
Frank Berry's Avatar
I don't think so but I may be wrong.
Of course, you'll get non-symmetrical clipping.
I have used non-symmetrical bipolar supplies on some of my video distribution amplifier designs when I don't have quite enough voltage from the PSU.
In that case, I had +10 volts and - 5 volts on the rails.
Frank
Old 9th October 2008, 11:57 AM   #3
Default re
So, a part of clipping, there is no sense to put a multitrimmer on one leg of the supply regulator to get the same output voltage equal to the other?
Old 9th October 2008, 12:11 PM   #4
easier to use a parallel resistor to adjust the output voltage.
regards Andrew T.
Adcom 5400 Power Amp Distortion - Need Help partialresponse Solid State 4 29th August 2005 03:26 AM
power cord for HP 331a distortion analyzer dhenryp Parts 8 23rd June 2005 05:27 PM
PCB Power Traces -- distortion from vias? jackinnj Everything Else 2 20th November 2004 04:50 AM
Distortion on Power Amp that goes away when tapped? distracto Solid State 1 15th November 2004 09:08 AM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Page generated in 0.08021 seconds (79.54% PHP - 20.46% MySQL) with 10 queries
