Old 8th October 2008, 07:43 PM   #1
Unhappy NAD T734 accident
I'm new here, so I hope I'm posting in the right place.
I just moved to China, and accidentally plugged my US-bought NAD T734 receiver into a Chinese (240V) outlet. I didn't notice it for a few minutes, until there was a small but sickening explosion. Not paying attention. Not enough sleep, lately.
The receiver is completely dead. I opened it up, hoping that a fuse had blown, but the fuses look OK, to me. On a smallish circuit board connected to the power input, it looks like one of the copper traces is completely melted off the board. I can't see any other obvious damage.
A few questions:
(1) Would you (the experts) expect the damage to be extensive and major, or only localized to a few components ?
(2) Any suggestions on what to check next (though I don't have much in the way of either equipment or expertise).
(3) Any suggestions about repair services ? NAD equipment is apparently made in China, but not sold here, so I can't find a dealer.
(4) If all else fails, anyone want to buy a crispy T734 ?
thanks
bk
Old 8th October 2008, 08:40 PM   #2
Default Re: NAD T734 accident
Try to post some photos for damage assessment.
Without expertise, you may better leave that to somebody else. The least you need is a multimeter to measure voltage and resistance. Then soldering equipment and a source for the spare parts. Does the NAD have a switch for different supply voltages? Usually at the back near the power input. If it doesn't you may as well wait until you return to the US (if you return that is), because it won't serve in China without an additional transformer. For the same money you might be able to get a new amp there.
Any electronics repair service should be able to help you there. If you are lucky, they even charge you less than for a new amplifier. Chinese are tough businessmen, especially when dealing with strangers.
Old 13th October 2008, 07:40 PM   #3
gfiandy is offline gfiandy  United Kingdom
Audio Engineer
gfiandy's Avatar
Hi, Labour tends to be very cheap in china and the techs out there are very resourcefull; you can probably find someone who will fix it for very little money if it can be fixed.
The likely problems will be overvoltage on the input parts to the voltage regulators so the smoothing caps may be damaged and the regulators may be damaged. The other problem is you will have put twice the normal voltage on the amplifier rails and this may have damaged some of the transistors and possibly the bulk storage capacitors in the amplifer although if you didn't play music through it they may have survived as there would have been little current flowing through them. Basically you can cause a lot of damage by doubling the input voltage to an amplifer but sometimes you get lucky and much more than you expect can survive.
Andrew
Old 14th October 2008, 01:28 AM   #4
Thanks for the comments, everyone.
Actually, I just noticed that I wrote the wrong NAD model number.
It's a T742, not a T734. Probably doesn't affect anything, though.
The amp does not have a voltage input switch. This is surprising, since essentially the same amp is sold in the UK (240v) and the US (110v).
I have a multimeter, and have tried measuring the resistance of a few components on the damaged circuit board. The ones I tried all had infinite resistance (according to my meter). Not a good sign, I suppose. I'm actually not sure what these components are, though.
I will try to find a good service guy, as you folks suggested. But, experience says I should have some idea how to fix the problem myself before negotiating a price with someone else. Especially in China.
I didn't play any music through the amp, so maybe the damage is not too extensive. I will post some pictures, but I'd be surprised if they tell you much.
I won't be returning to the US for two years, and I can't live without music for that length of time. If the service idea doesn't work out, I guess I have to go shopping. There's not much good gear, here, though, and it's all ugly silver/gold colored stuff. I like black. Yes, I know it's dumb buying criterion, but, as you can see from the original post, dumb is my specialty !!
Old 15th October 2008, 09:22 AM   #5
That only seems so at first glance. If you are in Shanghai, you are in one of the few places in the world, where you can get virtually everything. It helps of course to know some local people that show you the right places and make the right contacts.
And then there is still HongKong, from where they can send you all the stuff you need per web order.
Briefly subjected heaters to about 12v by accident. bigwill Tubes / Valves 6 20th July 2008 11:38 PM
Norick Abe dies in road accident. Zen Mod The Lounge 2 15th October 2007 04:26 PM
Had a bad accident with my TT21 today. Shoog Tubes / Valves 14 23rd March 2005 01:33 PM
CD6000 OSE - clock accident - Error 2,10,11 .... digitaldiablo Digital Source 1 13th September 2003 07:15 PM
unfotunate accident JOE DIRT® The Lounge 10 3rd July 2003 02:11 AM
Page generated in 0.11859 seconds (72.64% PHP - 27.36% MySQL) with 10 queries
