| Chip Amps Amplifiers based on integrated circuits |
I´m about to build a small amp using the tda7266. Do you think I need a buffer and is the schematic in the application notes ok or would you all like to add something?
http://www.st.com/stonline/products/...re/ds/1570.pdf |
#2 |
I built a small amp with a pair of TDA7350's,and followed the data sheet,it works well.
The circuit on the data sheet for the TDA7266 looks good to me. I would suggest using a larger filter cap though. 4700uf is probably a good start,adjust to taste.(I noticed on my amp that large filter caps helped the bass response.) ![]() Edit: Ohh,I don't think a buffer will be needed. Add an input pot/attenuator,and you should be good,for line-level input. |
#3 |
I tried building one of these, and for some reason I got it to work once, and then it died. I was using a 12v 1A HP printer power supply.
My only thought was that it might be that the ICs are electrostatic sensitive, and (although i did ground myself to discharge before working) I was not wearing an ESD wriststrap. I was never able to figure out what happened, but I just got another 2 of the IC's so I'm gonna have another shot at it. I used a 1000uf filter cap, snubbed with a 1uf film, and 0.1uf caps on the inputs. |
| Buffer for TDA7266? | jaste | Chip Amps | 7 | 2nd January 2009 07:33 PM |
| suggestions pls. | pamaz | Multi-Way | 2 | 23rd August 2005 09:01 PM |
| TML suggestions | Tyimo | Multi-Way | 20 | 4th March 2005 09:07 PM |
| Page generated in 0.26604 seconds (25.38% PHP - 74.62% MySQL) with 10 queries |
